Genuine GM T-Top Weatherstripping for Camaro's and Firebirds from 82-92.
GM Part #10198208 (RH) and 10198209 (LH) new in original GM box.
$340 for the set.
Sorry I don't know. I wasn't aware there was a difference. The GM parts book I recall looking at didn't differentiate 82-92. If you know what to look for I can check, I'd be interested in knowing myself if there is a difference.
Was trying to find a good way to explain and found this in a quick search.
GM had a few design changes for the T-Top Roof Body Surround Weatherstrip:
◦1982-1987 Used GM # 10198208 & 10198209
◦1988 (1st Design) Used GM # 10064550 & 10064451 WITH an Interlocking Slider Bracket being used
◦1988 (2nd Design) Used GM # 10198208 & 10198209 WITHOUT an Interlocking Slider Bracket being used
◦1989-1990 Used GM # 10198208 & 10198209
◦1991 VIN 186669 & Older Used GM # 10198208 & 10198209
◦1991 VIN 186670 & Newer Used GM # 10165494 & 10165495
◦1992 Used GM # 10165494 & 10165495
GM had a design change in the T-Top side roof glass seal as well. ◦1982-1990 and 1991 (1st design) VIN 186669 & Older used GM # 10165500 for each side.
◦1991 2nd Design VIN 186670 and Newer used GM # 10165496.
Thanks. Provided your information is correct this will basically fit all cars from 1982 to 1991 with the exception of
- 1988 T-Top cars with the First Design that had car had an "interlocking slider bracket"
- Late Model 1991 cars VIN 186670 & Up
^THE ABOVE^ This is for the roof glass seal which is a part of the T-TOP Glass which is not included with what I am selling, GM lists it as a separate part. It is Part No. 3 in the index picture in post #4 of this thread
The body side seals had a update (2nd design) that included small drain channels where the TTOP seal would set in them. There are a few other small differences in the mounting where the ttop pin receiver mounts are between the 1st design and mid 91 to 92 (body side).
(I only have 89-92 cars)
Hoping I didn't make you mad, just looking for which style you have. If the part numbers are correct, I think we know now.
Interesting and good to know. Not mad, thanks for chiming in. The seller (me) and the prospective buyer both have more information at their disposal. The pieces I have are in unopened GM Boxes, I don't think anyone will be disappointed with how they fit. Nothing fits like GM stuff that's for sure.
