Corvette Suspension
Old 05-21-2016, 05:41 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Corvette Suspension
Determining batwing centerline.
Batwing mounts installed.
Tubbing wheelwells
Control arm pockets
Eliminating the spare tire well
Mocking up the rear spindles.
Old 10-17-2017, 08:59 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Corvette Suspension
Why did you modify the spare tire well? Also, why did you change the geometry of the trailing arms?
Old 10-17-2017, 09:37 AM
soloc4's Avatar
I will not have a spare in the car, since I was already tubing the wheel well I cleaned up “the hump”, and I was going to locate the battery there (it’s in the cargo box now). The trailing arms were changed for better travel geometry and adjustability, the final configuration can be seen in the finished pictures.
Old 10-17-2017, 11:54 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Makes sense about the tire well then.
Is the C4 rear suspension inherently flawed in stock form? I can understand adjustability, but how did changing it change it for the better? I have the Doug Rippie (I think that was it) trailing arm brackets. I think they spread the body side points out slightly, but the way you did it drastically changed the geometry. Did you plot out the change you made? It seems more like you just wanted to use the stock 3rd gen LCA point
Old 10-17-2017, 12:38 PM
soloc4's Avatar
The original Corvette upper trailing arm forward mount point would have been too far inside the cabin to be practical for installation. I am not installing a roll cage as some others have done, and I want to retain the rear seat, or what GM calls a rear seat. The pictures you see were taken in the mock up stage, and the wood trailing arms were used to simulate geometry changes through the suspension cycles. The rear mock up brackets were scrapped after I settled on the final design. The original Camaro forward trailing arm mount was close enough to utilize in the final geometry to have no effect on the caster angles (caster remains zero through +4" of travel). That is also why a fabricated new trailing arms, strut rods, and toe rods.
Old 10-17-2017, 01:32 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Thanks for the response. Not criticizing, just wondering. If I ever finish my rear IRS swap, I was going to use the stock mounting points, regardless of interior intrusion, while trying to keep the stock rear seats. I don't see why I can't get the un-modified rear seat back in there with my plan, since the C4 point will essentially still be under the interior panel
Old 10-17-2017, 02:35 PM
soloc4's Avatar
You are correct in the point of it will all be contained under the rear kick panel, if memory serves, and it has been a long time since I did this, it came down to retaining the rear seat belt retractor. Mind you, I am not the leading authority on this mod, it’s just how I went about it. Like the saying goes “there is more than one way to skin a cat”.
Old 10-17-2017, 02:43 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Got you. I don't care about the rear seat belts, so that won't be an issue for me, I just want it to look stock on the inside
Old 04-23-2018, 01:55 AM
MyRedCamaro's Avatar
Glad to see someone else is doing this
senior bear
05-12-2016 06:22 AM
Hajile08
05-11-2016 11:07 AM
Jaime-TA-84
05-03-2016 09:35 AM
dbrochard
05-02-2016 06:57 PM
dimented24x7
04-22-2016 01:52 PM
Quick Reply: Corvette Suspension
