Pop up lights problem
Old 03-21-2017, 06:44 PM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Hi all,
So the headlights on my 84 Trans Am go up if I press the switch, no problems there.
However switching them off is another matter. If I simply click the off switch the lights will go off but not down but If I push hard and hold the switch for a second the RH light will go down but the LH won't. They both went up and down a few days ago so I'm wondering if it's the actual switch that is the problem?
I can hear relays clicking when I operate the switch. I know the motors in the lights are fine too.
Old 03-22-2017, 10:28 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: Pop up lights problem
Look in your engine compartment along the firewall. You should see a black box with embosed letters on it, saying "GUIDE".
That box is responsible for giving your headlight motors the right signals and may have to be replaced.
Old 03-22-2017, 04:18 PM
gta_knight's Avatar
Car: 1987 GTA
Thanks man i will take a look. I think i will also take the switch out of the dash and clean the contacts on it just incase...........but its never that simple where im concerned lol
Old 03-23-2017, 08:21 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You'll have a tough time finding that box on an '84.
https://www.thirdgen.org/forums/elec...headlight.html
Old 03-23-2017, 10:59 AM
gta_knight's Avatar
Car: 1987 GTA
Ha ha your right. My 87 has that module but this doesn't. So it's the 3 relays then.
I can hear them or some of them clicking if I push the switch but the light won't go down
Old 03-23-2017, 03:16 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Well, you never stop learning
Old 03-24-2017, 01:20 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Nope, he has the 82-86 3-wire headlight motors. The 87-92 2-wire motors used the headlight control module on the firewall with the word GUIDE molded in the cover.
One thing to try is check the tail light fuse. If it blown it prevents the headlight motors from closing.
Lon Salgren
Old 03-24-2017, 03:10 AM
gta_knight's Avatar
Car: 1987 GTA
Lon Salgren
the tail lights work and one of the lights goes up and down fine. Very occasionally when I try both lights go up and down fine so it's a bad connection somewhere. Just a case of finding where exactly.
I'm in the middle of cleaning the rear end up and installing new brakes and shocks so once I put all that back together I will.m
will move onto the lights
