What to reseal rear hatch area with after PO hacked access hole
Old 03-27-2017, 06:30 PM
Johnny*G's Avatar
Car: 1987 Trans Am
Engine: 355 Edel Int, SLP, Edel heders 8PSI
Axle/Gears: 3.45 Borg Warner
What should i seal the access hole with in the rear hatch area after the PO hacked a hole in the rear hatch area? I dropped the tank already to replace it for fuel neck leak. While i have it out, i would like to do the repair from the underside. Silicone caulking? Butyl tape with some kind of cloth covering? Thanks in advance guys
Old 03-27-2017, 06:53 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Transmission: Dynamic Racing Reverse Manual 700r4
Axle/Gears: 9 Bolt 3.45
Re: What to reseal rear hatch area with after PO hacked access hole
only real way to fix it is to weld new metal in. if you don't have access to a welder then you can rivet a piece of metal over the hole and use seam sealer (not silicone) to seal the edges.
Old 03-28-2017, 11:22 AM
Johnny*G's Avatar
Car: 1987 Trans Am
Sounds like a great idea! there are alot of 6cyl firebirds and camaros in the yards. I will head there and get a patch panel! Thank you
Old 03-28-2017, 11:27 AM
Croz's Avatar
Make sure you use a good seam seal and do it from the underside. If you do it from the top water, dirt and debris will have a way in to sit between the 2 pieces of metal. Seal it up good and there should be no issues.
Old 03-28-2017, 11:35 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Old 03-28-2017, 12:22 PM
LS2Swapped92's Avatar
Just weld this in, and be done with it, never drop the tank again. Unless your car is a collector car all stock or something, there's literally no reason to worry about an access hole done correctly.
I installed this with karropak felpro gasket material to create an air tight seal. There will never be fuel vapors, and the area is now more structurally sound with the 1/4 plate welded in and bolted in around the perimeter.
Seam sealer around the edges against the body wouldn't be a bad idea either
https://www.detroitspeed.com/Fuel-sy...-door-kit.html
Attached Thumbnails What to reseal rear hatch area with after PO hacked access hole-17038438_105230976675174_5471996761926380139_o.jpg
Old 03-31-2017, 09:50 AM
Johnny*G's Avatar
Car: 1987 Trans Am
Wow! nice work! do you still have the 3rd gen tank or did you upgrade to the plastic 4th gen?
Old 03-31-2017, 11:33 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I had the same predicament when I tore into my Camaro. Previous owner just cut a hole in the trunk area (with a metal cut-off wheel no less) and did nothing afterwards.
I made an entire post about my thoughts and dealing with it and what other members had done. You can find it here: https://www.thirdgen.org/forums/tech...rect-fuel.html
Long story short I welded in a 16 gauge plate (No way is the floor thicker than 18 gauge) with an oval cut out and secured a lid with riv nuts. I use a gasket in between the lid and body.
I did all of this with the tank out and drained. I also cut the lines and added in the female unions rated for higher pressure applications. I can now replace the pump and sending unit in 15 minutes or less.
Old 03-31-2017, 01:23 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
WOW. that looks not bad actually....
Old 04-03-2017, 11:29 AM
Thanks, I upgraded to a 4th gen plastic tank. I probably wouldn't risk welding with the tank in to be honest, too risky
