Air filter on carb has very little room.
Car: 1984 z28
Transmission: t5
I have an 84 z28 and it has a 350 in it with a carb, the space between the carb and the hood is quite small, as of right now it has no air filter, since its been in the shop since I got it. I've been looking around a bit for low profile filters, are there any recommendations for one that takes up very little vertical space? I'm seeing some at 2 inches, not sure if thats about as low as they go or not.
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
Re: Air filter on carb has very little room.
If you can't find a factory air cleaner look for a 14" x3" drop base air cleaner
Received 1,672 Likes
Problem with a "drop base" is, it ALSO drops the LID.
Doesn't matter too much what's under it, if all the air ends up having to skweeeeeeezzzze through a ¼" crack between the lid and the air horn.
Kinda comes with the territory with these cars. Firebirds are worse, their hood is flatter and lower.
Car: 1984 z28
Transmission: t5
Not sure exactly how much space there is, but the PO had a filter for a boat on there. Talk about sketchy. This is the carb, not sure what exact kind it is besides it being a edelbrock. Would something like this fit on this carb? https://www.summitracing.com/parts/s...d-ss/overview/
yes, that would probably work good. a drop base with the element type filter on the top will aid air flow.
Engine: 383 sbc
If you get a drop base you'll probably need the banjo bolt fuel inlet adapter for the carb so the air cleaner base doesn't kink the fuel hose going into the carb.
Car: 1984 z28
Transmission: t5
http://m.ebay.com/itm/301599411499?_mwBanner=1 is this what you mean?
Engine: 383 sbc
That's only the bolt. They sell the whole banjo fitting under the Edelbrock name.
If you switched the intake manifold to a Performer, you could get rid of that 3/4" adapter/spacer.
Car: 1984 z28
Transmission: t5
Could you link me to what you mean Biledriver? When I search Banjo Fitting i am getting quite a bit of different things.
Engine: 383 sbc
Edelbrock #8089 for the fitting. To bad you don't live by me I have a used Edelbrock intake for 87+ heads sitting on a shelf that would get you the room noemissons is talking about.
Car: 1984 z28
Transmission: t5
I'd like to slowly rebuild the entire car. Including the engine. So that will definitely be on the list
