Formula vin question
Hello all I have what I believe to be a original 1987 Formula 305. 5 speed car
Also I have just acquired another 1987 Formula 305 auto
I have used the vin decoder and for the type number both cars are listed as firebird. Not Formula/trans am Can anyone help with this question?? Thanks
Engine: 4++,350 & 305 CIs
Re: Formula vin question
Firebird and Formula use the same VIN prefix.
Trans Am and GTA use the same VIN prefix.
Oh ok on that decoder it had a placement for this letter I believe I'm referring to the S which is firebird and another letter meant Formula or trans am according to that chart?
Transmission: Pro-built 700R4
You cannot determine if a car is a Formula or GTA strictly from the VIN. You need the RPO codes the be certain.
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
You have to go by the RPO codes.
Axle/Gears: 9-bolt/3.45
Yes, there is a way to determine if a Firebird is a Formula just by using the VIN, alone, and that's with the engine code. If the engine code, its 8th digit, is an F or an 8, then it is a Formula, as base Firebirds could not have either TPI engine. However, if the engine code is H in 1987(E for 1988+), then you will have to dig into the RPOs.
And to summarize the other posts, a Formula begins as a Firebird, both have S in the VIN, and a GTA begins as a Trans Am, both have W in the VIN. There is no Formula/Trans Am.
Car: 1991 Firebird
Engine: 5.0 TBI
Anyone Happen to know a accurate as possible source to decode the PRO's on my 1991 Firebird?
Any help would be great!
Car: 1988 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 2.77 Posi
http://www.austinthirdgen.org/index.php?pid=30
Might be of some assistance. There are probably some other sources as well. You might have already, but give this site search a try. Might lead to more of the information you seek.
