what did you do to your thirdgen today?
i continued to battle with my heater core installation. I lost the battle today but the war goes on. I just received a new to me front ground effect that has some cracks in it. I put some epoxy on them. I found a plug on my throttle body that was unplugged and have no idea what it is. it was a busy day.
Re: what did you do to your thirdgen today?
Worked on making patterns do I can recover the steering wheel and shifter boot.
Well I'm going to try to do my own recover... starting off with vinyl and then figured if I can get it down I might start offering a service, but who knows. Was only going to do the shifter boot but my wheel is shot and I can't get anyone local to do it for a fair price.
ordered this new I.a.c plug. once it arrives I will solder it in place of the broken one I have now.
Bts1980 (01-07-2023)
I will look into it. as it sits the plastic case is broken. the lock isn't there and the 4 plastic tubes are missing. there are just 4 bare wires sticking out.
last night after dinner I decided to take a quick drive around the block. I wasn't going to drive it until I got the heater core back in but I couldn't help burning the tires around a few corners. I like this car.
it that way. ive always cut and soldered.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Finished putting my wiper blade arms back on. Had the windshield replaced and had them leave the arms off to repaint and replace the hose.
Car: 83 Pontiac Trans AM
Engine: 305 CFI
Replaced two sidemarker lights. Hope to figure out my wiper motor wiring this weekend.
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Took her for her maiden voyage! Besides a sticky throttle, vacuum leak and smoke from a coolant hose leak that decided to spring up she putted right along at a constant 30 MPH (because that's where the throttle was sticking! ) All of the above is getting sorted out starting first thing tomorrow
congrats liveit! nothing like the first drive. when you finally make something immobile mobile its like mechanical magic. doesn't sound like your too far away from having it squared away.
Did you get the adrenaline rush? I think it might be gone for me. We will see. I hope not.
I hear you on that. It's been four, going on five, years since mine last ran and I'm on the home stretch. If it doesn't start I'll probably cry lol!
Replaced a bad e brake cable, replaced the fuel filter, and started doing the AN fittings for the adjustable fuel regulator but hit a brick wall since I cant cut the braided stainless line without a special cutting tool. I tried taping and using a cut off wheel but it causes the braids to flare out. Hopefully the one I ordered from Summit will be here tomorrow
I guess I did know how to remove the terminals. I did that on a relay.
I got to work early and just kept staring at mine lol. I'm actually working on refinishing another set of front wheels to put on the rear so I have the same offset front and rear.
The following 2 users liked this post by Jbuchanan:
82firebirdlove (04-22-2021), KR81 (12-22-2020)
Not necessarily. GTA wheels have different offset front and rear. The wheels are actually stamped front or rear. If you look closely the front look deeper so I bought another set so I can run 4 of the same. Looks better to me and rotation won't be an issue.
She had a bit of a temper tantrum waiting in the drive thru line yesterday so next order of business is fixing the hacked up fan relay. Best of luck to both u guys on getting ur cars going!!
Car: 1988 camaro iroc z
Dealing with all the gremlins of a free car given to me. Speedo/odometer, cruise don't work, waiting to get underneath to find the coolant sender wire that suppost to be hooked up for temp guage,fixed some vacuum issues.plugs, wires cap and rotor are done yay I stomped on it to get across the street and it did nothing lol. Had to back off the throttle to let it catch up. Oh the headache
finished the new heater core install. have all heat and a/c functions now. next are replacing a bad IAC plug on the tbi and fixing the non functioning hi-beam switch. both should be easy and satisfying. anything's gonna feel quick and easy after the heater core.
Awesome thanks, I'll be on the look out for it tomorrow. I just figured it was bundled in with the wire attaching to the oxygen sensor.
drove 40 miles to work today. it was the first real drive after installing the heater core. I parked and as I walked into work I looked back and saw a puddle under the car. my heart sank thinking the heater core or hoses were leaking. I walked back over to see it was just a/c condensation. ear to ear grin!
had to add a little coolant to mine today. I'm not sure whats going on. it runs cool but every two or three days of driving if I check the coolant its down several inches. I haven't seen any leaks but its consistently a few inches down. i cant imagine where the coolants going.when you look into your radiator where does the coolant level sit?
took off the hood and fender for repair after that spill with that Honda got it pretty much squared away but have more work to do tomorrow
I bought n oem front ground effect off of craigslist. I got a great deal but of course it didn't come with hardware. I asked the forum where I could find the correct size for the bolts. I got a few vague answers but I really wanted someone to just give me the answer. I decided I would take the car to the hardware store and run in and out with bolts until I fond the correct ones. I happened to be on my back under the car when I noticed to my great luck there were still a few bolts attached from where the old ground effect broke off. today I removed them and the remaining broken fragments of the old effect and went to the hardware store to purchase bolts. tomorrow I will install the ground effect with the bolts and double sided tape across the top just as they did in the factory.
Reinstalled my repaired fender, beat a dent out of the hood and put 22 stitches in the front end. she'll get around and have some fun but so much for going to that car show in the morning
Car: 1991 Z28
Gonna tackle the pass side valve cover today, Did the drivers side the other night. worried a little about getting the new one on, That big thick wire loom that runs along the runners made just removing the old one a little tricky.
