Needle of the rev counter is moving a little bit in idle
Old 09-20-2017, 07:28 AM
Pupkin's Avatar
Hi,
do you have the same issue with your Firebird or Camaro 3.1 LH0?
I don't understand what the reason is. What could be wrong with the engine?
Thanks.
Old 09-20-2017, 09:34 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Needle of the rev counter is moving a little bit in idle
Likely nothing wrong with the engine. The tachometer is probably just old and the capacitors are drying out so the bedding built in isn't as good as it used to be.
Old 09-20-2017, 10:06 AM
Pupkin's Avatar
Thanks.
Old 09-20-2017, 02:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
The 2.8/3.1 engine idle weird from my experience. A little movement of the rpms is normal.
Old 09-20-2017, 02:34 PM
Pupkin's Avatar
Ok, thanks, 86TA.
