Firebirds for Sale Post your Firebird for Sale.
[PA] 1988 Firebird Formula project car (85% done)
Old 11-18-2017, 02:26 PM
dpmalibu's Avatar
Clean PA title
I have this 1988 Firebird Formula project car for sale. It is about 85 % done besides needing a paint job. Body is straight no rust. Floors are bedlined on the inside. They were stripped, primed and painted on the underside of the car. Passenger side floor had a small patch repaired professionally( welded in).Previous owner was pretty much doing a nut and bolt restoration. There is a lot of new parts on the car. All the suspension and steering parts were replaced. It also has a bunch of performance parts on it too. Spohn front/ rear sway bars, Spohn Tubular front lower control arms, bolt in sub frame connectors, Spohn pan hard bar and rear lower control arms, BMR torque arm and new aluminum drive shaft. All motor and trans mounts were replaced. All suspension hardware were replaced. It also has a new madrel bent Y- pipe 2.5" with 3" outlet. Also have 2.5" mandrel bent( intermediate) pipe. Motor is 305 TBI with Holley throttle body. Trans is a 700r4. Car has 84,000 original miles. Rear was replaced with an 9bolt posi disc brake rear. There are alot of other new parts on the car that I didn't mention. I also have about $700 worth of parts for the car to pretty much complete the car. Car needs brake/ fuel lines and exhaust to get it back on the road. Interior needs headliner, carpet , rear seat and put interior back together. Could be done in one long weekend. Car currently not running since there are no fuel lines. Car ran and drove prior to the start of the restoration. Asking $3000 b/o.
I have about 80 pics or so if you need anymore than what is posted.
This is a perfect father and son/ daughter project.
Pics coming
Old 11-18-2017, 05:01 PM
dpmalibu's Avatar
Re: 1988 Firebird Formula project car (85% done)
Old 11-18-2017, 05:04 PM
dpmalibu's Avatar
Old 11-18-2017, 05:12 PM
dpmalibu's Avatar
Old 11-18-2017, 05:18 PM
dpmalibu's Avatar
Old 11-18-2017, 05:20 PM
dpmalibu's Avatar
Old 11-18-2017, 06:04 PM
Drew's Avatar
Pssst... The tie rods are backwards. They should be on the back side of the centerlink. The outer and inner are also reversed. Outer go grease zerk down, inner the grease zerk faces the center of the car.
Old 11-18-2017, 06:18 PM
dpmalibu's Avatar
I didn't put it together. I see what your saying. Not a huge deal. Somebody will have to correct that when they buy it. I would have appreciated it if you sent your message in a pm rather than on my thread. Pointing out negative things are not going to help me sell it. Thanks for bringing it to my attention.
Old 11-18-2017, 06:34 PM
Drew's Avatar
I figured you'd want to know about something easy to correct, that would improve chances of making a sale. Sorry if it didn't come across that way.
Old 11-18-2017, 06:44 PM
dpmalibu's Avatar
No problem. If I have time I will get to it but luckily it's not that big of a deal if I don't get to it.
Old 12-19-2017, 07:00 AM
dpmalibu's Avatar
No longer for sale. Car is being parted out. Body has been scrapped
