High idle issue
Old 11-20-2017, 06:59 PM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
High idle issue
I have a 85 z28 305 tpi. It idles around 1400 rpm when starting and as it gets hot it rises to about 2000 rpm sometimes a little higher. I've replaced the tps, o2 sensor, fpr, coolant temp sensor, spark plug wires, distributor cap, rotor, and ignition coil. I still have the same issue tho, I'm beginning to think something is wrong with the computer
Old 11-20-2017, 07:03 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: High idle issue
Have you tried to do the minimum idle speed adjustment to see if the iac is moving in all the way ?
Old 11-20-2017, 07:05 PM
Engine: Lb9
Transmission: M20
Re: High idle issue
http://www.iroczone.com/2009/10/adju...ir-idle-speed/
Old 11-20-2017, 07:20 PM
Engine: Lb9
Transmission: M20
Re: High idle issue
Looks like there site is down. Follow this procedure.
Old 11-20-2017, 07:21 PM
Re: High idle issue
Actually don't think I tried it that way yet. I tried setting minimum Idle but it didn't change anything
Old 11-20-2017, 07:26 PM
Engine: Lb9
Transmission: M20
Re: High idle issue
Originally Posted by Jp's camaro
Yep tried that
Did it bring down the idle when commanded in ?
If not the iac might be stuck and needs to be cleaned.
The cts will tell the ecm the target rpm. The cts doesn’t necessarily have to throw a code 15 to be faulty. I assume you have checked for vacuum leaks ?
Old 11-20-2017, 07:30 PM
Re: High idle issue
Edited my original post because I haven't tried that yet, I did clean the throttle body a bit when I changed the fpr it wasn't really dirty and changed the coolant temp sensor already. Haven't found any vacuum leaks, egr has been disconnected so I capped those vacuum lines
Old 11-20-2017, 07:33 PM
Engine: Lb9
Transmission: M20
Re: High idle issue
It might be the ecm, you can wrap on the ecms case to see if it drops idle or surges the engine rpm. Here is a link to a 1226870 if you need it.
https://m.ebay.com/itm/1985-TPI-Cama...m_gL4TyW11TQWg
Old 11-20-2017, 07:37 PM
Re: High idle issue
Thank you I'll try that and see if it does anything
Old 11-22-2017, 03:50 PM
Re: High idle issue
Found out if I turn the key off and on 3 or 4 times before I start it, it will sometimes idle normal
Old 12-28-2017, 12:55 PM
Re: High idle issue
Update: just replaced the ecm with a reman one and still having the same high idle issue and fan not kicking on. If i unplug IAC, maf, or tps it still does the same thing
Old 12-28-2017, 11:23 PM
Re: High idle issue
Anyone ?
Old 01-01-2018, 11:26 PM
Pro
Pro's Avatar
Car: 1992 Z28 and 1995 Silverado
Engine: 5.7 TPI and 5.7 TBI to TPI convert
Transmission: 700R4 and 4l60E
Axle/Gears: G80 3.23 and open 3.42
Re: High idle issue
- Have you hooked up a fuel pressure gauge and watched it while idling, making sure it hangs out around 30psi when idling?
- Information from the ECM is helpful. Purchase some sort of scanner if you can and post data. A laptop with TunerPro RT and this:
http://www.moates.net/aldu1-and-cabl....html?cPath=64
would be very nice
If you dont want to learn tunerPro you can at least get something like:
https://www.ebay.com/itm/12-Pin-ALDL...r/272388698454
It will dump data to a CSV file as your car is running.
- Youtube is free and just about everyone has the ability to record video, so upload video when you get a chance
Old 01-02-2018, 08:40 PM
Re: High idle issue
Haven't checked fuel pressure yet, did fix the fpr tho. Thanks for the advice and yeah I was thinking about just getting a cable so I can see what's going on but I'll check the fuel pressure first
Old 01-20-2018, 06:56 PM
Re: High idle issue
I finally fixed the high idle issue I believe. The connector to the coolant temp sensor was somewhat broken and I believe it wasn't making a good connection. When I was testing the sensor today I messed with the connector a couple times and it began to idle down and is now at about 900 rpm
