BLMs and Spark Plug read contradict each other
Trying to dial in the tune on the LT5. Just when I seem to be close to finalizing based on BLMs, I pull plugs and they don’t indicate what the BLMs are saying. Specifically, my plugs are a very dark brown suggesting the tune is rich but the BLMs are reading in the 133-135 range. I’m tuning to within a +/- of 3 to 128. The heads and top end have been ported, larger cams, and 3” exhaust w headers.
I’ve ordered a pair of Delco O2s to see if that changes things. Thoughts?
Re: BLMs and Spark Plug read contradict each other
Dom, there's no real contradiction there.
Keep in mind that BLMs in the 130’s do not mean you’re actually running lean. It means the ECM is adding fuel to keep you from running lean. You wont actually go lean (>14.7 on average) until the BLMs top out and there’s no more room for adjustment.
You can lower the O2 thresholds, yeah. Though if it's anything like $8D, that'll have the effect of lowering your BLM's since now you'd be commanding more fuel for the prevailing O2 threshold.
I did the opposite... I raised my O2 thresholds (particularly high map thresholds) since the car likes a little richer mixture at part-throttle high-load conditions...(like around 13.5 to 14.0). that ended up raising my high-map BLMs, which forced me to raise the VE values in the corresponding cells.
Basically if you can target specific map regions with your O2 threshold adjustments (like we can in $8D), it'll limit collateral impacts to the VE tables...
I’ll see if the new O2s make any difference. I have had that issue before where new O2s make a significant change in the tune.
New O2s arrived. I throw them on and we’ll see if that makes a diff. I kniw its a “throwin parts at it” but its a fairly quick inexpensive way of eliminating a possible issue. Besides, I’ll have fresh O2s in the motor which is not a bad thing.
RBob,
Replaced the O2s. The ones that came out were black and sooty. I hope to drive the car tomorrow with the same calibration and want to see if the change makes a difference. I'll keep u posted.
Car: check
Engine: check
Transmission: check
RBob.
Interesting your comment. The LT5 is a high rpm motor. Even w 4.10s the motor is only turning 2000 rpm at 80 mph which is just above idle for this motor Do you think this suggests that the O2 thresholds should be lowered because of that?
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Why not tune in open loop? So much easier in my opinion. You already have a wb installed. You will eliminate the o2's which get fouled out then they foul out the plugs. Surging idle problems and inconsistent a/f ratio's made me switch. What rpm's are you turning at idle? Increasing rpm's at idle with the bigger cam will help a/f ratio at idle. If you need to pass inspection put the o2's back in when needed.
I have a WB permanently installed. I can see the swings back and forth LEAN/RICH. I'm tuning Closed Loop so relying on BLMs.
Did you try open loop with wideband only to dial in first before going to closed loop?
Currently, the car idles at about 900-950rpm
Well part of it is that the LT5 suffers from a similar “split blm” issue as other LT motors. Maybe a bit worse. I have been recently “tuning” out KR in mainly cruise area of the SA table which is the 1800-2400rpm/45-70kPa range. The motor has heads, top end ported w larger 63mm TB, intake and exhaust cams. Exhaust is 1 7/8” headers into 3” ID SS exhaust.
Ground strap seems to indicate the right heat range for the plugs. I’ll see what results, if any, I get w the O2 sensor swap out. If nothing, I will put back the next step hotter plug, NGK BKR5E heat range instead of the 6Es.
A 6 ngk usually works well for most performance builds. So i wouldnt think that be too cold. Plug threads will also tell heat. Whats the compression?
I have run turbo cars with 7-8 range plugs just fine which are very cold for low compression cruising. They do get dirty rich lookin in time even at stoich. May want to try touch leaner esp at idle since overlap may skew o2 sensors
Yeah it is sequential. I took it out after installing new O2s with no significant difference in the BLMs, although I did notice that as MAT increased correction the BLMs came down at least at idle. I'll also note that idle is at a lower kPa than previous. Its lowered from 52 down to 47kPa telling me its pulling better vacuum. I'm leaving the calibration as is and trying BKR5E plugs tomorrow. :Let's see.
I guess I'm surprised you could end up with split BLMs on a sequential system. wouldn't you simply tune the injector trims individually idle like GM did with the LT1s?
Unfortunately no such capability in the LT-5. We have 4 VE tables due to the port throttle system, 16 injectors and 32 runners. The O2s trim the individual banks. But they work off the same VE cell. The LT5 engine management is a bit of a bastardization of the L98. The LT1 came later and incorporates what they learned from the LT5.
So the latest is that I lowered the O2 thresholds and that helped a but I don’t want to lower them further because they were already lower in the stock cal. The motor feels that it likes the BKR5E plug better than the 6E. I tried raising SA again but started to pick up some KC at a steady cruise as I had in a previous thread. The Knock occurs during steady cruise at about 1800-2000rpm and shows upwhen the road begins an incline. In the LT5, AE is based solely on MAP differential not TPS%, so I can maintain a steady foot on the throttle but MAP will change say from 45-60kPa or a delta of 15kPa, and that’s when I will see the KC increment. So this is why I dropped timing. It was to eliminate the KC at steady speeds. Otherwise I don’t get KCs.
So my question is, did I drop timing to eliminate KC but in the meantime lower timing is giving me a more incomplete burn?
Am I creating s problem trying to solve a lesser problem?
Well I can’t say enough about what a “treasure” RBob is when it comes to this stuff. Sent him a couple of pics of the plugs I had been using, NGK BKR5E-11. He took a look and recommended I go w equivalent Autolite because he thought the NGKs were suspect and possibly could even be COUNTERFEIT. Holy smoke he was right. I went out and got a set of Autolite 3924. My BLMs snapped into place w just a couple of tweaks and the rich looking plugs aren’t rich any longer. I’ve attached pics of what I sent Bob before and one of the result.
One difference I noted was that the Autolite plug has a longer nose, it projects further into the chamber than the NGK ALTHO OVERALL LENGTH IS THE SAME.
NGK #5
NGK from 2&8
NGK top, Autolite bottom
I’m curious as to what would make you think the ngk were counterfeit? That seems really odd to me
The autolite cross references with ngk 5 and 6 so not sure how the heat range compares exactly but seems odd it made that much of a difference unless the ngks were indeed counterfeit and not truly heat range 5 or 6
There's just no #%!&-ing way my Camaro would he running as good as it is (with a batch fire Miniram no less) without their expertise being so freely (and patiently!) given out.
Got the NGKs and the Autolites from Advance Auto and AZ.
I cant imagine them being counterfeit
in any case strange results imo. Little bit of projected tip i would not expect to make a big difference like that. Plug gap and heat range changes in the ngk didnt help, maybe the autolite is hotter? Idk
Well, the change was pretty significant. I just finished a 700+ mi round trip to MI. Once the motor cools off, I’ll pull a couple of the plugs and see what they look like. I do know already that my gas mileage was noticably better. The engine “note” was very consistent. I didn’t “hearr” individual cylinders. Just a consistent rrrrrrrrrrrrrrrrrr. I’ll also measure the differenc ein the nose projection between the two plugs
Projected nose plugs
Regarding "projected nose" plugs, I found this to be educational and it is very similar to the difference between the NGKs and the Autolite plugs
So here’s the latest. Drove the ZR round trip to MI for business. Put 700mi on Autolites. Posting pics. Trying to figure why the discrepancy in the cylinders. BTW, the car felt great the entire drive and got 22-23 mpg averaging 75+ mph.
The plugs look darker in the pics. When u put light on them, they are more of a lighter coffee brown. They aren’t black.
But again, the variance in the coloring is odd. Clearly looks like uneven fuel supply for some reason. A bad fuel regulator would affect all injectors equally I would imagine.
Plenum was recently ported along w cylinder heads and injector housings. Done by someone who’s done them many times before.
Don’t I wish I could trim the fuel w a modifier for wach cylinder LOL!
Yes the LT5 plenum/injector housing combo has 3 different direction changes before the air gets to the chamber. Having said that, these results are a bit confusing.
I beginning to suspect oil in the number 2&4 cylinders. There’s a crankcase vent located next to the intake for those 2 cylinders. And there’s been cases of oil getting sucked past the gasket into the cylinder. They needed to do a better job of keeping fluids away from each other in this motor.
Dominic- I have NGKs and I’m not I impressed with them either.
I have a set of AC Delco Rapid Fires that I will replace them with. I haven’t run Autolites before - but the AC plugs have never given me an issue.
The issues you mention sound a lot like what I have seen on my NGKs as well. Mine were gapped at .035” too. I gapped them to .045” and am running and MSD A6 unit. Still, I am seeing the same thing with plugs, AFRs, and BLMs that you are seeing.
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Has nobody modified the LT5 bin to have VE tables for the different cylinders?
Or a multiplier per cylinder?
Seems like if it’s already sequential throwing in a multiplier that references the cylinder could easily be done. Id have already done it for the $8d code if it was.
Short answer is no. No such mod to the cal. There are 2injectors/cyl depending on whether the secondary runners are open or closed which I suppose would add a level of complexity. Perhaps a modifier to the VE table for left and right banks would be a start.
Engine: LB9
Axle/Gears: 3.08
I don’t think that would complicate it too much but I’ve never looked trough the bin.
maybe 2 multiplier tables. One for each set of injectors per cylinder.
the code is the same, you’d just add an extra jump to the same subroutine. An extra 5 minutes of work if that.
of course that is if the coding is as basic as $8d. Which I think it probably is close.
The LT-5 was a modification of the L98 code. They started working on it in 86, so its pretty much a derivative. There are only 8 injector drivers. The 2ndarys are driven off separate relays but take their PW signal from the associated primary injector. When secondarys are energized, the cal cuts PW by .51 so now both injectors effectively deliver the fuel of one injector.
VI,
I have a pretty complete .xdf. Not sure if that helps. Also there are 8 different versions of the LT-5 xdf altho they are very similar if not the same. They moved stuff around but its the same "stuff" at different addresses.
Before I start tearing into top end of motor, I thought I would first check the injectors thinking perhaps something obvious would show. I ran a resistance check on the injectors. The primaries ranged from 14.6-14.8 ohms,
while the secondaries ohm'd out at 14.1-14.3. All pretty consistent. This does not definitively rule out injectors, but its a start. If I don't find evidence of a particular cylinder sucking in a bit of oil, I'll have the injectors cleaned and flow tested.
