Torquing Down Obscured Head Bolts
Old May 30, 2021 | 01:54 PM
MrCaswell's Avatar
Car: 1986 Trans Am
Engine: 5.0 L (305 LG4)
Good Evening everyone, today I am continuing the process of installing a new set of World Products 305 S/R heads on my 1986 Trans Am. Currently I'm removing the old head bolts on the passenger side and it has occured to me that the clearance between the hanging exhaust manifold and the cylinder head makes the prospect of torquing down to spec (and even removing) these lower head bolts quite challenging. Can anyone who has done this before recommend a newer member some tools or techniques? I would prefer not to entirely remove the exhaust manifolds if possible. Thanks in advance.
As a side note, I haven't bothered yet to remove the ild spark plugs because they are either siezed or somebody has used gorilla force on them in the past.
Old May 30, 2021 | 02:17 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Torquing Down Obscured Head Bolts
You say your removing the old original heads to replace with new ones, so why would access to torque the bolts on the old heads matter
As to removing what's there, if the manifolds are giving you access problems with the head bolts, why not remove them first?
Dealing with stripped/rounded manifold bolts does suck, no doubt about it... BUT! Dealing with a rounded head bolt sucks X 10 , I'd be removing that manifold to absolutely insure clear access to the head bolts...
Old May 30, 2021 | 02:39 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Just go ahead and bite the bullet and remove the exhaust manifolds so you can get a socket straight-onto those head bolts. Sure, you might be able to use a 1/2" u-joint on the socket with an extension and sneak it through there to get the bolts out, but you can't use a u-joint to correctly torque the bolts when the new heads go back on. Proper head bolt torque specs are absolutely vital to the health of your engine.
Old May 30, 2021 | 02:48 PM
MrCaswell's Avatar
Car: 1986 Trans Am
Thanks for the reply. I was referring to torquing down the new head bolts after the new heads are installed. I suppose I'll just have to remove the manifolds entirely.
Old May 30, 2021 | 04:04 PM
need-for-speed's Avatar
That's the ticket. Better to go to the trouble to remove the exh manifolds rather than remove those new heads later for a blown head gasket (due to improper head bolt torquing)
Old May 30, 2021 | 06:29 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I am not sure why you are worried about the manifold bolts. you've already gone and remove the hardest of them, now you just need the Y-Pipe bolts undone.
But you'll have to yank them if you want to do this right.
Might also be the perfect time for headers.
Old May 30, 2021 | 10:05 PM
I was thinking headers too. Why not not?
Old May 30, 2021 | 10:14 PM
MrCaswell's Avatar
Car: 1986 Trans Am
Those nuts really didn't want to come off, but I managed to remove not only the manifold but the head as well.
trevorsmith82
Sep 23, 2011 02:17 AM
lbrohez
Sep 19, 2005 11:45 AM
scanman717
May 10, 2004 01:45 PM
rezinn
Jul 17, 2001 01:28 AM
Justin Moore
Sep 25, 2000 08:59 AM
