I have most of the front end parts from my 86 which need a new home, nothing wrong with any of them just changed the car drastically and can't use them anymore. Fuel system parts as well, high end stuff.. All parts have been on the car for under 10k miles over the last 15 years or so. All have normal wear and installation marks.
***Added some pictures at the bottom
***Sold. J&M camber plates, black. $100
***Sold Adjustable wonder bar, black altered from a non adjustable Spohn bar. $40
***sold AGR quick ratio steering box, firm sport valving. $200
***Sold Inner tie rods and outer bumpsteer kit. $75
***sold Front Koni yellow sports. $275
***sold Complete front C5 brake swap, spindles, hubs, rotors, braided hoses, calipers. Calipers are older 2 piston Z06, may need rebuild, were working fine. $300
***sold Ground Control front weight Jack's, 1050lb springs. $250
***sold 2 row aluminum radiator, champion or griffin, dont remember. No leaks. $75
Nasty performance aluminum fuel tank. $300
Aeromotive A1000 pump. $200
Aeromotive regulator, for carburated, 10an ORB ports. $100
Aeromotive? 10an fuel filter, iirc 100 micron stainless filter element with shutoff valve. $50
I don't have time to ship anything quickly right now so local pickup/meet up is best. I really just need these parts gone to a good home, we can make a deal on multiple parts, single prices are FIRM. The fuel tank is still in the car.
Hi, I'm interested in the AGR steering box. How did you like the steering feel? Any comparison you could make to other aftermarket boxes or relative to a stock Iroc or Z28 box?
Assume it is leak free and still tight?
Do you happen to have any pics of the Spohn control arms installed on the car?
Would be interesting to see the offset being used, if that makes sense.
My build isn't quite ready for these, but it is getting very close and if they are still available, and look strong enough for a 500 wheel HP street/show car, then I would be very interested.
Dennis, I can't find any good picture showing the control arms and tire clearance and I can't put them back on the car either as all the mounts are altered. They fit an 18x12 wheel with 8.5" of backspacing on a 3rd gen width axle, so if thats what you are planning to run, they would fit.
