Where to get door window molding?
I am looking for the door window molding. Mine is all cracked but I either don't know what it is called or was unable to find a replacement. Any help is appreciated though I have a weird feeling that those may not be available anymore.
Here is what I am referring to:
Re: Where to get door window molding?
Belt weather Strip/ Window Scraper Seal
1992 CHEVROLET CAMARO 3.1L V6 Belt Weatherstrip / Window Scraper Seal | RockAuto
Buy FAIRCHILD brand if you can,... by-far the best fitting aftermarket window weatherstrip I've used. The last set I bought was thru JC Whitney, but I don't know if they still carry them. FAIRCHILD also makes the best door seals around too.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I got mine from 1A a while back,check them out or classic
