88 IROC 5.7 tpi, warm start issue
Re: 88 IROC 5.7 tpi, warm start issue
If you have to floor the gas, that's "flood clear" mode which turns the injector pulses off so that excess fuel can be drawn into the engine and got rid of, and probably means that an injector and/or FPR is leaking fuel into the intake.
[QUOTE=sofakingdom;6584349]If you have to floor the gas, that's "flood clear" mode which turns the injector pulses off so that excess fuel can be drawn into the engine and got rid of, and probably means that an injector and/or FPR is leaking fuel into the intake
Thank you
Thank you
