1989 LO3 Camaro Tuning
Old May 5, 2026 | 08:06 AM
sleeper84's Avatar
Car: 1989 RS
Engine: LO3 5.0L
Axle/Gears: 10b 2.73
I have a 1989 Camaro LO3/TH700R4 car I'm freshening up some. Full tune up done, Edelbrock TBI intake, NOS GM Distributor, new NTK O2 sensor, rebuilt throttle body, Jet adjustable FPR, air horns ground off the throttle body and an injector pod spacer. 195 degree thermostat, 215/203 fan switch from a Celebrity (IIRC), factory exhaust with a Flow Master muffler and 89 ethanol-free AMOCO gas.
First steps are the usual. Bump base timing a few degrees and then trying to get my LTFT/BLM in line with the FPR. I just got it started Sunday after a lengthy manifold swap (cracked manifold and other issues) and, no, I don't have a fuel pressure gauge installed ATM. I need to see if my fuel pressure test kit has an adapter for it this evening.
From a short stint of data monitoring yesterday evening, my BLMs were around 105 which is pretty rich (15% ish if the info I found of 0.8% per count is correct). I dropped my FPR about 3 turns and got them in the 110 range cruising, but still 108 at idle. I assume this is fairly normal since it's a static FPR and not vacuum modulated.
Next was timing. I had it set at 0 per factory spec but I've read about guys adding as much as 10 degrees to these LO3s. However, at 3 degrees, I get a smattering of spark knock instantly when I go WOT from a dead stop. That seems to not be there once the car begins to move.
The car has 98k on it and as far as I know, it's the original driveline. Someone has had the intake off before but beyond that, I don't see any signs of the engine being out. I'm going to drop it back to 0 degrees for the time being and put some miles on it with good fuel and a healthy dose of Seafoam and something with PEA to clean the chambers and ports up some. I'm also using the Valvoline Restore and Protect 5w30 to help clean up the inside of the engine and hopefully the pistons and rings.
Once I get closer to 128 on the BLM, I'm going to hook up my WB02 and see what PE and Open Loop looks like. I have a 427 ECM I would like to swap to with headers and a modern catalytic converter to do away with the AIR clutter under the hood.
Old May 5, 2026 | 01:48 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: 1989 LO3 Camaro Tuning
This is the only item on your list that I can comment on. And I believe your experience to be pretty typical. The swirl port heads don't like or need much advance to work well. It's part of their design. The next gen Vortec heads are similar...they take a bit more timing, but nothing like an earlier SBC head. When my Camaro RS was new (L03 and a 5-speed with 3.08 gears) I added a degree or two, but beyond that it was not happy. I did leave a degree or so in it, as it seemed ever so slightly more responsive to throttle input, but the difference was not measurable in the 1/4 mile.
Old May 5, 2026 | 02:54 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I echo this. 0 to 2 deg (with the EST disconnected) is all these heads require.
Old May 5, 2026 | 07:22 PM
sleeper84's Avatar
Car: 1989 RS
Engine: LO3 5.0L
Dropped timing back to zero and that cured the rattle.
As for the BLM, I lowered the fuel pressure till it was stumbling off-idle and sluggish and the BLM came up to 111. I've got more reading to do.
I have the '427 ECM from a 95 K2500. I'm still trying to figure out what all I need to do to be able to swap it in and not even bother with the factory one.
Old May 10, 2026 | 09:05 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I ran my old '92 for years and a lot of daily driven miles with the timing advanced 10*. I did run premium fuel though, as it was cheap then and it would tend to ping on regular. The butt dyno said the car performed better. I recorded my mileage on every tank and best mpg was achieved with the advanced timing.
I don't think the mpg increase would be worth it these days though. Big cost difference between regular and premium.
Old May 13, 2026 | 07:57 PM
sleeper84's Avatar
Car: 1989 RS
Engine: LO3 5.0L
I found a second hand Moates setup so now I'm working on putting together a BIN for the '427 ECM.
Dave from GearHead EFI recommended starting with the BHMD BIN and add the AIR controls from the BHMX California truck tune.
I've been digging through the file in TunerPro the last two evenings and I think I have everything set for the TH700R4 and AIR function.
@Fast355 I'm going to post progress here as well. As to our IAT/MAT conversation, I've been searching and reading some this evening and I'm curious why GM did away with them on the TBI engines and if I need to worry about having it set up on my '427 swap. For the moment, it is on in my BIN just because I had set it previously.
Old May 14, 2026 | 06:12 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Is Rbob's EBL Flash no longer a thing? That used to be the way to go. I still have it for my LO3 swapped for a LO5. However, I just tried google him and I can't find his website.
Old May 14, 2026 | 06:24 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
@RBob is Rest in Peace chasing those electrons in the sky.
Rbob/Dynamic EFI
@Buccaneer bought Dynamic EFI. Xfire Performance LLC
Old May 14, 2026 | 06:47 PM
Rbob/Dynamic EFI
RIP!!! bobR was such a helpful person! I actually bought the system twice, both times he helped me through some tech issues. Amazing to see it will be making a comeback. OP I'd follow that and/or see if you can find a EBL ECM some one is trying to sell.
Old May 14, 2026 | 06:57 PM
sleeper84's Avatar
Car: 1989 RS
Engine: LO3 5.0L
That had originally been the plan. But with it in flux, scoring the 427 ECM and a good deal in a Moates setup, I'm going to start with that.
I'm fighting to keep myself from ordering a bunch more parts till I get the swap done and my front suspension rebuilt.
Old May 15, 2026 | 08:52 PM
Gotcha gotcha! I 100% understand you there. I'm always finding myself thinking about 'the next part', when I still have so many other jobs in front of me!
Dbrannon79
DIY PROM
Mar 10, 2026 10:25 PM
AvantiHall
Oct 2, 2012 11:21 PM
oldred95
DIY PROM
Dec 27, 2010 02:48 PM
Grumpy
DIY PROM
Apr 27, 2009 01:46 PM
DAVECS1
DIY PROM
45
Sep 4, 2002 05:13 PM
