Prothane Cobra rear spring isolators
Old May 10, 2026 | 02:37 PM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
For anyone who is curious or planning on changing their rear springs this is the stock isolator and the prothane 6-1709 for the new edge Cobra with IRS. Probably half an inch thinner overall than the originals.
Old May 11, 2026 | 06:27 AM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LHO
Transmission: Tremec TKX
Axle/Gears: 3.23 Torsen
Re: Prothane Cobra rear spring isolators
Very interesting.... just changed all my springs recently, I'd been thinking about the rear isolators and how thick they were.... for $28 on Summit, I might give these a try, see if I can close the gap in the rear wheel wheel even further. Looks pretty dang close, I just wonder how well they'll sit around the mounting bump on the body
Old May 11, 2026 | 09:37 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
link for them
https://www.summitracing.com/parts/ptp-6-1709-bl
Old May 11, 2026 | 09:40 AM
exiled350's Avatar
They fit the body with no problem. The picture is a bit misleading because the stock ones have a tapered hole in the center where the prothane ones are the same diameter through.
Old Yesterday | 01:06 PM
exiled350's Avatar
This is how it sits with cargo coils in the back and moog 5660(?) in the front.
Old Yesterday | 02:39 PM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LHO
Here they are with Ground Control weight jacks/ eibach springs at full low in the rear, and raised a lil in the front so I can clear ramps. Easy install, and they fit perfect
Evilokc
Dec 3, 2022 12:29 PM
Mkos1980
Sep 26, 2011 02:20 PM
87350IROC
Sep 14, 2010 10:43 AM
Stevo
Jul 27, 2007 02:14 PM
