Sick of the rake...wanna go lower then pro-kit
Old Jul 25, 2007 | 03:08 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Other then weight jacks, what kinda springs will give me a good lowered stance and a nice spring rate. I like sportlines but i hear they have a softer spring rate...is that true? Anyone know exactly what the springs rates for pro-kit and sportlines?
Here are a few pictures of my car with pro-kit with the rear insulators removed...i hate the rake...whats strange is my friend has pro-kit with 17s and his rear does not sit as high as mine does. Im happy with the front i just cant stand how the rear looks...do you guys have any suggestions?
Old Jul 25, 2007 | 03:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Sick of the rake...wanna go lower then pro-kit
my car sits like that WITH the isolators in, but my fronts are lower by just alittle bit.
i'd love to remove my rear isolators to get rid of the rake, but the 4th gen rear would make my tires crush my fender lips
you could try taking just alittle bit of the coil off the spring to lower it some.
I have also heard the sportline rates arent really stiff
Another option is a custom coil spring.. i do believe there are companies that will make custom length and rate springs. you just give them the specs you want like dimensions (width I.D./O.D. and height) then spring rates. that will be the perfect stance dialed into your specs. I've only heard of ppl doing this and never looked for companies that do this
Old Jul 25, 2007 | 05:28 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
You could go with coilover conversion. http://www.spohn.net/product.cfm?productid=1533 I think that will give you up to 3 inches of drop----fully adjustable so you can put the rear where ya want
Old Jul 26, 2007 | 04:51 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
I'm in the process of getting away from the pro-kit myself, but im going to weight jacks. The rears are already in.
As far as off the shelf springs, the only ones Id consider are Guldstrands springs, but I'm not sure on ride height and I've heard speculation that they are only cut moog springs...which if you're up for some experimenting cutting stock springs can have great results as long as you don't get carried away.
Old Jul 26, 2007 | 05:05 PM
Stevo's Avatar
Im up to it, but im just not comfertable with it without knowing really what kinda spring rates im messing with. Hopefully someone can post there springs and how much they cut with rideheight and handling differences.
Weight jacks on the rear? How did that work? Moved the spring perches? What are you using for the front?
Old Jul 26, 2007 | 08:36 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
try cutting small amounts of coil off the rears to see if they get you where you want. I'd start with 1/8th or 1/4 of a coil and keep using a tape measure until the car is even.
Old Jul 26, 2007 | 10:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
a small amount of coil shouldnt hurt much. Eibach prokit rears are progressive rate springs tho, i think they go from 110 all the way to a peak of 170 lbs. cutting a small mount willl raise that peak rating but it shouldnt be a big deal as you can get away with a stiffer rear spring. i hear lots of ppl running 200-250lb springs in the rear for roadrace/autocross.
Old Jul 26, 2007 | 10:42 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
My car rides fine with the sportlines, i don't race it or anything but its pretty low and rides comfy. Note: the front sits high as hell because the front springs aren't fully seated in the spring pockets.
The green car has prolines i believe ( they are grey like the prolines but i havent check )
Old Jul 27, 2007 | 02:14 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Here's a pic of my prokit with 17's
Attached Thumbnails Sick of the rake...wanna go lower then pro-kit-nightside.jpg
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
