vibrations
Old Apr 1, 2003 | 09:32 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
vibrations
HITHERE am getting HITHERE really bad vibration aroung 65-70 mph, it seems to be coming from the driveline somewhere. It also seems to get worse when HITHERE take it out of gear and let it coast at that mph. Does anyone know what could be causing this?
thanks
Old Apr 2, 2003 | 05:04 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
tires out of balance...driveshaft (common).u-joint....tranny mount...motor mount....steering components.....I would start with having the tires balanced.
Old Apr 3, 2003 | 05:38 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
Well I took the driveshaft out and had it checked and it was out of balance while the shaft was out I turned the pinion just to check and I could feel the bearing grinding. I have not pulled it apart yet to verify but I hope it is only the bearings.
Old Apr 3, 2003 | 10:31 PM
Engine: 406
sounds like you found your problem...or problems . ....hopefully there is no damage in the rear..is the gear oil up to level? usually there will be some leakage with the bad bearing......any problems there?
Old Apr 4, 2003 | 11:36 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
well I had to replace the pinion bearings but the gears were ok, I did find out that I have 3.23 gears and not 3.42 gears so I quess I need to change my sig.
Old Apr 5, 2003 | 01:54 AM
Engine: 406
amazing what you can discover, when you remove the cover!
Wow! I 'm a poet!
Have a great weekend!
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
