South Central Region Board for the states of Texas, Oklahoma, and Louisana.
TPI lower intake
Old Feb 27, 2004 | 12:02 PM
steven90GTA's Avatar
From: Tomball Texas, right outside (north) of Houston
Car: 1990 GTA and 83,99,02 Trans Am WS6
Engine: 350 TPI,CrossFire 305 and LS1
Transmission: 4L60 and 700R4 and 4L60E
Axle/Gears: 90-3.23,83-3.42,99-3.73,02-3.42
TPI lower intake
My friends camaro blew an intake gasket and while at the shop, the guys there said his intake is corroded and that he will need a new one do any of you guys know where he could get another intake for a decent price, quick? Does it matter if the engine is a 305 or 350 b/c were not sure. (its a TPI lower intake as stated in title)
Old Feb 27, 2004 | 12:10 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
What year is his car?
Old Feb 27, 2004 | 12:16 PM
camaro year
His car is a 85 but the guy said it had a 88 IROC 350 motor but were not sure b/c there is no dipstick hole with the stock manifolds so we think it is an older 350/305 block so the newer manifolds don't have a provision for a dipstick on the drivers side like the older manifolds did and it doesn't have centermount heads.
Old Feb 27, 2004 | 12:28 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
The intake I have is for the new heads (89 - 92). It will work as long as you drill out the center holes.
Or, you can bring the intake to my shop and I'll see if I can repair it. I've gotten some pretty bad intakes to seal just fine.
Old Feb 27, 2004 | 12:38 PM
intake
What holes do you need to drill out and how much would you want for that intake? and could you drill out the holes?
Old Feb 27, 2004 | 12:47 PM
Would it matter if its 305 or 350 are they the same intake
Old Feb 27, 2004 | 12:49 PM
Val's Avatar
Val
his intake is corroded?? How the hell did that happen?? I can't even imagine the kind of coolant problems he must have that would corrode aluminum bad enough to warrent replacing the whole manifold.
Old Feb 27, 2004 | 12:54 PM
it also happened to my dads 93 throttlebody 350 in his truck not sure if its aluminum or not
Old Feb 27, 2004 | 01:15 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I have one for sale off of my '88 350 that I could send down with a friend of mine tonight, but I will need to know soon, for he is leaving at 5:00 to come down to the tomball area.
Old Feb 27, 2004 | 01:31 PM
intake
How much would you want for the intake and do you know if there will need to be any modifications made to it to work with the older heads
Old Feb 27, 2004 | 01:50 PM
I'm sorry, I called my friend and I think that he is already gone. Once I get to the house I can check to make sure this one is okay, but if he already isn't gone, he will by the time I make it to my house.
When are you looking to get one in, maybe I could ship it out in the morning or something.
Old Feb 27, 2004 | 01:59 PM
intake
How much do you want for it?
Old Feb 27, 2004 | 02:16 PM
Val's Avatar
Val
I know one thing. I'm flushing the Iroc's coolant with distilled water this weekend!!!!
Old Feb 27, 2004 | 02:32 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
The intake is the same on a 305 and 350. What makes a difference if the year of the intake / heads. 90-92 and I think 89 all have the same bolt pattern.
85-88 have the same bolt pattern.
The new intake's 4 center bolts (2 on each side, in the center), on a 90-92 are angled different than the 85-88 intake / heads bolt pattern.
All it would take is just drilling out (elongating the 4 center holes) to use the older with the new and vice versa.
Hope that makes sense.
I can probably repair that corroded intake and seal it for you no problem.
Old Feb 27, 2004 | 02:37 PM
Val's Avatar
Val
Dont forget about the coldstart injector on the 85-88 as well.
Old Feb 27, 2004 | 03:16 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Cold start injector only has to do with the fuel rails and runners. Both lower manifolds have provisions for the CSI.
Old Feb 27, 2004 | 04:13 PM
Val's Avatar
Val
Never realized that.
Old Mar 1, 2004 | 05:36 PM
Re: intake
Sorry, I have been working. I am not sure, I will use it if I don't get rid of it, so I haven't thought of a price. I am going to put it on a 69 chevy for a show truck. Let me know if you are still interested.
Old Mar 1, 2004 | 05:39 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I have a buddy that has a John Millican converted LT-1 intake for sale. It comes with the intake / fuel rails / fuel rail AN fittings / brand new remote thermostat housing.
Let me know if anyone is interested.
Old Mar 1, 2004 | 07:52 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
how much mike?
Old Mar 2, 2004 | 08:57 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
PM me for details. I dont want to "advertise" on the boards and have my post deleted and get another PM from a moderator.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
masonta
Aug 31, 2015 10:14 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
