South Central Region Board for the states of Texas, Oklahoma, and Louisana.
need help in dfw area (plano)
Old Jul 16, 2004 | 01:03 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
hi guys,
i need some knowledge help, my car wont go and id like to change that
i have a 84 Z and i live in plano, my problem consists of my hydrolic system for the clutch or some problem with my clutch install. i have been trying to trouble shoot and i have narrowed it to these two things.
what i need help with is checking and then changing if needed my clutch master cylinder.
today i will be checking my clutch disc i hope. but i need help checking the master cylinder, i see no leaks but i cant be sure.
today is friday so if any one is up for helping me this weekend id be obliged to feed you and such
Old Jul 16, 2004 | 01:15 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
im not in texas, but you can try posting at the North Texas Thirdgen Assoc board:
http://www.gmperformance.org/NTTGA/
Old Jul 16, 2004 | 01:52 PM
Engine: 350ci
hey i cant check my email so i cant have a user name yet can you post for me? if you could thatd help me out alot, put my Phone number in the post so they can call, 972 985 4692
Old Jul 16, 2004 | 01:56 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i posted it... hopefully someone will help ya out.
Old Jul 16, 2004 | 02:33 PM
IROC-T's Avatar
Check the resevior for the clutch if it's not very low it's probably not leaking. Then you'll know it's the clutch disc,or pressure plate (or related too these).
Old Jul 16, 2004 | 05:38 PM
Engine: 350ci
i have bleed the clutch already today to no avail
its the master cylinder being the original worn out unit it is or its the disc
going back out now to finish taking the tranny off to check the disc...
Old Jul 16, 2004 | 08:48 PM
Engine: 350ci
howdy
i took it all apart and the disc is strait the pressure plate is fine and every thing looked fine except for the fork which wasnt on its little pivot ball right.
ill be putting it back on the bell housing tomorrow.
still if any one can come over and help me look at my clutch master cylinder thatd be so great. ill prolly order pizza for lunch
Old Jul 16, 2004 | 10:39 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'm in Plano, too, near Independence and Parker. But unfortunatley I'm tied up. Once you get it put back togethee with the pivot ball in properly, hopefully your problems will be over. I've enver messed with the hydraulic system on my clutch, but I've been told if that truly is the problem it's a lot easier to buy a complete pre-bled hyd. clutch kit from the dealer and just install it.
What are the symptoms/problem you're experiencing? Maybe someone can help you out in that area?
- Vern
Old Jul 17, 2004 | 01:09 AM
Engine: 350ci
prob
see here
Old Jul 17, 2004 | 09:08 PM
Engine: 350ci
its works now!
it was the fork and pivot point.
Old Jul 18, 2004 | 09:55 PM
vernw's Avatar
GREAT NEWS!!!!! Glad you got it worked out!
Old Jul 19, 2004 | 10:54 AM
Engine: 350ci
new problem, radiator has started to leak the night i got it running, gonna pull it today or tomorrow, inspect and leak check it...
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
