South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Engine Swap ??'s. Please Help
Old Aug 4, 2004 | 06:00 PM
RAGEman's Avatar
Car: 87 Camaro Z28
I have been calling around local Salvage Yards, In search of an L98 to replace my LB9. My plans were to find an L98, Rebuild it w/ Vortech heads and the SDPC intake, and be set to go. I cant find not one L98. But what I did find opened an idea in my mind. Can I not buy a 5.3L or 5.7L Vortec Engine out of a newer model Chevrolet truck and put the SDPC intake and TPI on top and be set? Let me know if this has/can be done. If so, what things would I need to change....(mounts, wiring, computer....etc.)
Old Aug 4, 2004 | 09:55 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I don't see why not. The Vortec 5.7L already has the vortec heads...just get the Vortec TPI bottom, and a used TPI wiring harness, runners and plenum and it should work.
The 5.3L is an LS-type engine. That's a totally different can of beans there. I think your best bet would be the Vortec 5.7.
You can prob get a decent vortec 350 outta a late 90's Chevy truck for not too much. Good luck on the swap!
Old Aug 9, 2004 | 07:44 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
actually the 5.3 /5.7 out of a newer chevy truck has the ls1 style coil pack with no distributor so you would have to convert to make it work. the heads and intake you want to use would not come anywhere close to fitting. i think 99 and up started using this design
Old Aug 9, 2004 | 06:56 PM
RAGEman's Avatar
Car: 87 Camaro Z28
What about the 98 Chevy 5.7L Vortec?
Old Aug 9, 2004 | 06:58 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
The Vortec 5.0's and 5.7's in the Chevy trucks used the traditional distributor setup. When they replaced the 5.0/5.7 with the 4.8/5.3/6.0 Vortecs they went with the coil-near plug setup. I think his best bet would be the Vortec 350.
Old Aug 9, 2004 | 07:01 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
If you're sure it's the 350 then I'd say go for it. It's easy to tell the difference between the old style 5.7 and the newer 5.3's etc. If the engine you're referring to has a distributor then it's the old style. If it's a 350 and not a 305, then go for it.
Old Aug 12, 2004 | 12:27 AM
89ROC's Avatar
I'd do the LT1 swap, since those motors are getting so cheap. Call Ron @ 972-475-5656
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
