new member
Car: gmc syclone
Engine: 4.3 v6
new member
hello....signed up today...hope you don't mind me lurking around...search function didn't work for me w/out joining...here to learn a bit about custom tuning the 749 ecm..... most tuning newbs at syty.net are directed to the following link as a "read this first" which is from here...good stuff... https://www.thirdgen.org/newdesign/tech/promintro.shtml i'm in the process of learning to navigate rt tunercat using the intronics pocket romulator....use datamaster as a scantool and just purchased a plx wbo2....just went through a pretty thorough build on my .030 4.3 turbo motor and fired it up on stock 33 lb injectors and a stockish .bin...to be running a 3bar map out of an 89 turbo t/a...my pte turbo has a 70 mm wheel...need to brew up a startup program to run my 72lb injectors using tunercat....nobody that i have found has a bin even close to what i'm looking for...i have modded 2 ecms with the correct mosfets for use with low impedance injectors...my truck currently runs and drives under its own power, but runs out of fuel very quickly if i get on it more than half or so throttle....if anyone thinks he/she could set me on the right track, would be very grateful...also, if need be, i will gladly compensate you for your time as i realize this can be time consuming....
thanks,
servando
thanks,
servando
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Welcome to the board!
I know there's a wealth of info if U look in the right places on the Thirdgen board. Good Luck!!!
Car: 1985 Iroc-Z
Transmission: t-5
welcome to the board. You should post up in the DIY PROM section https://www.thirdgen.org/techbb2/for...?s=&forumid=16
Car: gmc syclone
Engine: 4.3 v6
thanks very much folks...there is a wealth of info here....i'm finding that alot of the questions i have are actively being posted or have already been asked...plenty of reading to do...
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Welcome dude! Pasky's from Laredo, maybe ya'll could meet up and race
Welcome to the boards! You gonna be able to make it to any gatherings?
Welcome to the boards! You gonna be able to make it to any gatherings? Thread Starter
Car: gmc syclone
Engine: 4.3 v6
i hear his car really moves...also watched it do a baseline dyno when it was white... Moderator
Car: 1989 IROC Z-28
Craig
Car: gmc syclone
Engine: 4.3 v6
Originally posted by Zap Racing
YES THERE IS--there is probably more than u want to know.U can (I have) spent countless hours researching any subject about thirdgens, and on some boards unless U do a search first about a subject, if it's a frequantly asked question, some people will get downright nasty with U. Always do yourself a favor and hit the search button first!
Craig
Craig
Car: Kitt
Engine: Classified
hey, i'm pretty certain that I know him...he own's the black lt1 hybrid....nice guy for sure....i'd look forward attending any future gathering...are these gatherings limited to third gens or gm in general? as far as a race, i'm always down for a friendly run...as long as it's from a dead stop
jk Pasky
Have you seen the post about the H-Town Gathering March 26? Pasky's most likely gonna be comin', maybe you 2 could cruise up to Austin, and cruise with us down to H-Town for the gathering. I've never seen a Syclone up close before. I've only seen the tail lights:lala: Thread
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
LT1Formula
Oct 8, 2015 08:34 PM
