South Central Region Board for the states of Texas, Oklahoma, and Louisana.
305 or 350?
Old Jun 26, 2005 | 05:00 PM
k's89rs's Avatar
Car: 89 rs, bmw 325 is
Engine: 360 (.060) 2.5L inline six
Transmission: 700r4, 5-speed
Axle/Gears: 9 bolt 3.08 3.? limited slip
305 or 350?
Just like the title keep my 305 and work it or swap a 350 in it.
My two issues are
a.Interchangeability between 350 and 305 parts
b.injection
305
i want a 305 simply for the fact of my last well know post about 4th gens. What would be cooler than have a small bore 305 wax the hairs off of an ls1's butt? I know this is possible because........i dont know i want to make it possible! also i have the block for it and i know it bolts to my car. only issue is heads?
350
easier to grab parts for. need we say more.
injection
tpi or carb
tpi
fuel economy. efficiency. expensive
carb
poor fuel economy. easy. less expensive.
i guess what im asking for is opinions and knowledgable people about 305 builds.
kent
Old Jun 26, 2005 | 06:41 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
350
Old Jun 26, 2005 | 06:42 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
350
Old Jun 26, 2005 | 06:43 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
350
Zap Racing's Avatar
Car: 1989 IROC Z-28
In case i didn't make myself clear,
350!!! 350!!! 350!!!
Max easier HP is non computer carb.
Unless/until U learn how write chips or have a chip tuner buddy in yur pocket, injection will always be harder to deal with overall.
Old Jun 26, 2005 | 06:50 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Re: 305 or 350?
kent
Do a couple searches in general engine about 305 vs. 350 and start reading--come to youe own conclusion. I'm pretty sure it will be 350 (or 383)
Old Jun 26, 2005 | 09:59 PM
k's89rs's Avatar
thats what im thinking too craig.
its alot easier finding parts for 350's than small bore 305s. now what i could do is get a 350 block and put a 283 crank in it and turn it into a 305. been thinking about that too. carb is definitly looking like the better choice right now.
Old Jun 27, 2005 | 02:55 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
If you're gonna do that u pretty much have to go non computer carb, because i built a couple like that when i used to race dirt circle track cars. To make that run good U are gonna have to rev the crap out of it--"7000+" and computer injected engines do not lend itself very well to that type of concept! (IMO)
Old Jun 27, 2005 | 11:25 AM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
Depends on what you want to do with your car. If you are talking about racing, then you definitely want to start with a 350. If you are more into cruising and freeway driving, a 305 is a perfectly good motor.
I had a 91 Z28 with a stock 305, 700r4 auto and 2.73 gears. It was great for long drives, I drove it down to Houston from Detroit and got excellent gas mileage.
I have a 91 Formula 350 now, with a TH350 and 3.83 gears. Great at the strip, 1.8x 60' times and running in the low 13s. But it sucks on the freeway, about 3300 rpm at 70 mph, and I figure about 6 mpg!!
As far as interchangeability of parts between the to motors, in my experience just about everything is interchangeable. Exeptions of course would be pistons and injectors. I don' know about the bottom end, rods, crank etc?
Old Jun 27, 2005 | 11:46 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
350..
I wouldn't waste my time with a 305. I've owned both and I must say, there is no choice as to which one I would choose to own next.
A 305 may have good gas mileage, but thats not just because of the size of the motor. 350's can get just as good mileage with a proper tune and proper parts. My bone stock 305 w/ an LT1 cam runs very smooth, but I must say, the power is just not there. Its really not going to be there unless you throw quite a bit of money into it. Once you get the speed bug, there is no stopping and you will be kicking yourself for sticking with a 305.
350 engines are just as ubiquitous as a 305 and the parts are even more common. You just cant beat the bang for the buck price of 350 engines. Do yourself a favor and just forget about the anemic 305.
Old Jun 27, 2005 | 04:07 PM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
you can always say your real 350 in your car is a 305 cause it looks exactly the same....and im pretty sure you can always say your real 383 actually in your car is a 305...at least I think they all look the same.
But coming from a 305 guy myself ...i'd also get a 350/383 maybe a crate motor would be the best way to go for some of us ...especially since you got a TBI you can easily make it into a Carb .
I built a motor one time...and if you got experience, time, and money then go for it ....but you can find some real good deals on already quality built motors especially carbed. I personally am going to save up for a LS1 or LT1 swap once i can get enough time on my hands
Old Jun 27, 2005 | 06:32 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
i have a funny story, i was street racing about three years a go in my red iroc and hustled this ls1 guy into giving me 10 and the move for a hundred dollars saying my car was a 305 on gas. he had a stock ls1 on gas. he didnt know my car was a 388 on gas and i dont think he ever figured that out. lets just say me and 5 of my friends went to hooters the next day on his 100 bux
Old Jun 28, 2005 | 01:35 PM
k's89rs's Avatar
ok so 350 seems to be the choice. thanks for your help and advice.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
