10 bolt 7.5" rear end is stock right?
Car: '91 Formula
Transmission: TH350 built
I bought a cover for my diff from summit, like the one Extremeiroc had a the mod party deal. Just want to reconfirm I purchased the right one as stated in the title to this message.
Should be good for 5HP right
Car: '91 Formula
I spent quite a bit of time searching the rear end and tranny board without success. I will try a post there as well. Jay knows the answer
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
start reading:
https://www.thirdgen.org/techbb2/sho...ight=ring+gear
OOps wrong search result--here's what I meant to post:
https://www.thirdgen.org/techbb2/sea...der=descending
with the information you posted its most likely the correct one. There aren't too many GM 10 bolt rears.
If its this one then its the correct cover.
Car: '91 Formula
Thats it, 7.5" GM 10 bolt one. Thanks, im goind to install it this weekend
Car: '91 Formula
Naw, too lazy with the cold weather and Christmas shopping etc. Im shooting for this weekend for sure.
I wanted to get that exaust work done at ARD last Saturday but I was not feeling well that day. Now this Saturday is Christmas eve day. Im off on Thursday and Friday, I wonder if it could be done then. I will call over there.
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
I know owen is trying to catch up some projects before next week because he is in the bahamas from the 26th-30th
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
