South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Hey Coz - You're Rich
Old May 3, 2006 | 03:36 PM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Hey Coz, figured I 'd start a little thread for you and your running rich problem.
Please post up your engine specs and history, plus the flu bug symptons.
IIRC, Carb'd 305 with a recent rebuild?
Are you sure the choke isn't sticking? That would make it rich, and keep times and performance off.
Old May 3, 2006 | 04:51 PM
Mr.Wolf's Avatar
Car: 87 Z28
Engine: uh does the name give u a hint
Rebuilt 305, edelbrock intake mani. model ?????, Edelbrock Carb Perform 600?, whole msd 6al, set up with pro billet distrib., and blaster 2 coil, edelbrock tes headers.
Everything is coming out fine now
Old May 3, 2006 | 05:42 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Hey Coz,
Are U still running computer? partial--full-or none?
Old May 3, 2006 | 05:45 PM
Mr.Wolf's Avatar
Car: 87 Z28
na m computer is now a paper wait
Old May 3, 2006 | 07:47 PM
Wheel Spin's Avatar
Axle/Gears: BW 3.27
Why?
Come on, more info.......
Old May 3, 2006 | 10:52 PM
Mr.Wolf's Avatar
Car: 87 Z28
i took out the quadra jet rochester, and had all these wires in the way, that i didn't need, that were continuing to end up resting ont he headers. so i figured wtf and just ripped them out.
Old May 4, 2006 | 08:39 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Is the distributor a computer controlled type or the "old" stand alone type that does not require computer control?
Old May 4, 2006 | 02:40 PM
Wheel Spin's Avatar
Axle/Gears: BW 3.27
We could be getting somewhere.....The "Stock" replacement dizzy's have computer controlled advance. I have the MSD Pro Billet in my car.
Old May 4, 2006 | 03:18 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Hey COZ
Well, if it's a computer controlled dist, then assuming the computer is still in the car controlling the dist, without all the input from the other sensors that were uh..err..umm...deleted, there ain't no way in hell that car will ever run right. The brain is not getting the info it needs to know when or how much to advance the timing.
U either have to put all the computer sensors back on and working correctly or take out that dist and put in a NON computer dist, where we can set the advance like the good ole days.
AND THERE'S NO WAY AROUND IT--IT EITHER HAS TO BE ONE OR THE OTHER!
I'd be real interested to put a timing light on it to see what timing at idle is, and what timing is at 1500/2000/3000/3500/ETC
Old May 7, 2006 | 12:36 PM
Mr.Wolf's Avatar
Car: 87 Z28
the computer is not connected to anything
Old May 7, 2006 | 12:46 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Is it a computer controlled dist or a regular stand alone dist?
Old May 7, 2006 | 03:51 PM
Mr.Wolf's Avatar
Car: 87 Z28
its a standalone pro billet distrib. that you plug into the msd 6al box
Old May 7, 2006 | 04:50 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
The 10.7's U were running at HMP is equal to about 16.70's in the quarter mile--based on other cars with similar setup- I would think we should be able to get your car at least in the 15's, with some tuning.
I'd still like to put a good timing light on it to see where the timing is from 1000 to 4000 at 500 rpm intervals.
When RudyT had his, if I remember right, he had similar mods and he broke his into the 14.9's out at HRP at the Fall Brawl.
Old May 13, 2006 | 11:44 PM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
yeah i ran that last time. But remember, i had 305 TPI with just edelbrock headers and a/c delete and free mods. A big difference than Coz's setup
tglennon11
Sep 23, 2015 05:30 PM
Jk_Under
Sep 8, 2015 08:13 AM
toyotekk
Sep 7, 2015 06:36 PM
apie2546
Sep 5, 2015 07:40 PM
90formulaVortec
Sep 3, 2015 09:26 AM
