South Central Region Board for the states of Texas, Oklahoma, and Louisana.
these tires look dangerous??
Old May 25, 2006 | 03:40 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
I was looking at these tires on Jegs. They say they are DOT approved drag radials. They have so little grooves in them they look like they would be dangerous in even a little rain.
Old May 25, 2006 | 04:09 PM
Mitre#136's Avatar
Car: 88 Pontiac Trans Am
Engine: 5.0L
Transmission: 4spd auto model unknown
Those tires don't really look like they were meant for everyday driving, although, they look awesome for racing, (track) applications....slick.....
Old May 26, 2006 | 12:52 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
^ are you someone I know???
As far as the tires go...I sure wouldn't use them on the street. Eagle F1's fro street racing.
Old May 26, 2006 | 01:00 AM
Car: '91 Formula
Im larry with the red 91 formula. Say you last sunday at the dyno day. Im the good looking older gentleman with hat and shades.
Anyway, I already ordered the tires. I only drive my car about 100 miles per month so I think Im ok. IM going to kick *** at the strip
Old May 26, 2006 | 08:12 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
What are U gonna do with the old slicks?
Size?
Old May 26, 2006 | 09:23 PM
FbodTrek's Avatar
I know who YOU are silly!
I was tlakign to the new guy
Old May 26, 2006 | 10:27 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Im larry with the good looking red 91 formula. Say you last sunday at the dyno day. Im the older gentleman with hat and shades.
there, i fixed it for you ,... sorry, i just couldn't resist
Old May 27, 2006 | 11:02 AM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Old May 28, 2006 | 11:14 AM
Car: '91 Formula
I just wanted to be sure he didn't confuse me Barry or Craig
Old May 28, 2006 | 11:44 AM
Wheel Spin's Avatar
Axle/Gears: BW 3.27
I can GUARANTEE the DOT drag radials won't bite if wet...see my Baytown thread.
Old May 29, 2006 | 02:39 PM
Barry 85IROC's Avatar
Car: 1985 IROC
Engine: 355 4-bolt
Transmission: Specially-Built Exner TH350
good looking?????? kick ***?????????what's he been smokin'???????????????????
Old May 31, 2006 | 03:02 PM
Car: '91 Formula
Size?
They are Nitto Drag Radials 275/60/R15. I have them on a 15x8" rim. Note, they are 15" rims. I was going to hold onto them until I determine that the new ones are working out ok, then sell them on the board here. PRobably a high HP street car might buy them. They don't have many miles on them.
I guess a thirdgen guy could get a cheap set of 15" rims and run em
Old Jun 1, 2006 | 11:33 AM
Car: '91 Formula
got the tires, WTF?
https://www.thirdgen.org/forums/orga...=1#post2915188
I posted this on the racing board for a wider exposure. Comments?
Old Jun 1, 2006 | 01:25 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Larry,
In some NHRA and IHRA classes they made it a rule many years ago, that for some particular classes that they were trying to keep under control, that U must run a street legal tire. It was to keep cost down down and to keep racers from showing up with big butt full wrinkle wall slicks.
In order to get an advantage, the racers went to the tire companies, and said produce a DOT (Department of Transportation) legal tire that hooks up better than regular tires.
Over the years the tire companies have pushed the envelope more and more, for better tires, but to pass DOT specs the tires MUST have tread on them! That is why they have minimal grooving.Just because they are DOT approved does not mean they are recommended to use on the street.
It means it is a tire built to pass the MINIMUM specs to get a tire DOT approved. It is basically a raidal constructed sidewall with a couple grooves, just so they pass DOT approval!
Old Jun 1, 2006 | 02:58 PM
Car: '91 Formula
Larry,
OK, Im going to put them on and see how they go. Like I said, the farthest I would ever drive the car is to a meet or the track. A guy in the other thread said that since they are radials, they would have the bands in the sidewall that won't make them squirrely on the freeway like during a lane change, like an ET street or other non radial would.
Old Jun 2, 2006 | 06:55 PM
Car: 1985 IROC
Engine: 355 4-bolt
ET streets are scary on the freeway.
Old Jun 3, 2006 | 10:54 AM
Car: '91 Formula
Yeah but these aren't ET Streets. They are a Radial tire that has the bands for sidewall support,unlike ET streets. They are just like other drag radial except they have even less tread. According to a guy on the other thread I put about this in the racing section, the onlly difference I should see between these and a regular radial is wet traction.
Old Jun 3, 2006 | 09:51 PM
Car: '91 Formula
Well I got em on today. They look great and feel great. I havent really been able to jump on them, just driving arouond my neighborhood with little kids riding bikes, etc.
Im going to the strip this Friday
heres a pic
Attached Thumbnails these tires look dangerous??-image005.jpg   these tires look dangerous??-image006.jpg
Old Jun 4, 2006 | 01:20 PM
Car: 1985 IROC
Engine: 355 4-bolt
That's what I'm saying....your tires will be fine on the freeway, as long as it's not raining.
Old Jun 14, 2006 | 12:25 PM
8898z28's Avatar
dude i saw a guy with nitto 555s on his rear
you know the all weather tire
it was around 1am in the fall (you know when it feels wet outside but its not) anyway i was cutting turns up 35e at around 120 mph in dallas by the zoo and his car just washed behind me and almost hit a wall, he said he felt like he was driving on a bar of soap
i have the bfg comp ta's kdw 285/40/zr17 on my 98 and im putting around 380 hp to the wheels and she does fine in the rain and when its a little damp out and never breaks loose like those wonderful nitos
just dont drive in the rain, at night in neighbor hoods with sprinklers, or in the fog, or when its a little damp out, or behind cars that might be leaking water because their over heating, dont race on roads you have walked to make sure theres no bad spots and um yeah just dont drive your car on roads you dont know and youll be fine
Old Jun 14, 2006 | 02:12 PM
Car: '91 Formula
Im only leaving the house in the car when there is zero % chance of rain. We almost never have fog here, only a little in the mornings sometimes. Freaking sprinklers are a problem though. They have them in the landscaped center areas of the road sometimes and they go all over the place. I remember going through some sprinklers one time with my car after I just washed and waxed it. As far as racing, the only racing I do is on the drag strip, so no water there.
InfernalVortex
Apr 20, 2021 11:31 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
