South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Progress update on TH350 swap.........
Old May 28, 2006 | 09:08 AM
Barry 85IROC's Avatar
Car: 1985 IROC
Engine: 355 4-bolt
Transmission: Specially-Built Exner TH350
Well, after one LONG DAY, TH350 is in the car, cooler installed. Left to do: finish cooling line, 2 bolts in bell housing, tighten cross-member, torque-arm bracket (one bolt), and install shifter. Found out that my clutch has been slipping constantly. 5000 miles and the clutch disc was GONE(on the flywheel side). Flywheel hammered, pressure plate marginal. Clutch simply wasn't holding. Too much torque. My fault. Didn't buy enough clutch. Will be done today (Sunday).
Old May 28, 2006 | 09:31 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
So, I guess U don't need the external cooler I offered U?
Old May 28, 2006 | 04:28 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Sue wants to know.......does it go VROOM...VROOM yet?
Old May 29, 2006 | 07:10 AM
Car: 1985 IROC
Engine: 355 4-bolt
The conversion kit came with a B&M cooler!(much to everyone's surprise).
And yes, it does go vrooom,vroom. Drove it home yesterday. We all know nothig ever goes as planned.(Murphy's law is alive and well). The stock T-5 bracket is not the same as a 350 bracket.Larry Dunlap was a life-saver. Came through with a B&M conversion bracket to avoid delaying the install by several days. Thanks, Larry. I gotta get taller street tires, though....................General observations so far........
MUCH FASTERNo more slipping clutch. Motor has WAY MORE POWERthan I thought.
Old May 29, 2006 | 08:19 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Congratultions!!!
And I mean that, from the bottom of my fart!
Did the 700 shifter I gave U work, or did U have to get a real 350 shifter?
What stall TC did U end up with?
Have U made any WFO runs, all the way thru the gears?
Why do U need taller tires? U got 3.73's that should be just right for your combination--should put U thru the lights right at a little over 5000.
So, are U 100% finished or still have little things to finish up?
Old May 29, 2006 | 10:49 AM
Car: 1985 IROC
Engine: 355 4-bolt
Shifter works, 3000 stall, no WOT runs. Taller STREET tires. 4200 RM on freeway (no idea how fast I was going. new speedo not in yet. I was passing everybody.)
Thing to finish up.....removing all the clutch crap, modifying the shifter plate to allow me to put it into park, hot-wiring the neutral safety switch (so I don't have to push in the clutch to start it)Little odds and ends (back-up lights, etc.)
Old May 29, 2006 | 04:37 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
So, how long U figure before it's track ready?
I'm surprised U havn't had your foot in it yet!
Old May 29, 2006 | 05:20 PM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Originally Posted by Barry 85IROC
....3000 stall......
OK, so maybe I WON'T beat your 60'.....
You still want the stock 700r4 neutral safety switch I have? PM me the address info, I'll mail it to ya.
Old May 29, 2006 | 06:45 PM
Car: 1985 IROC
Engine: 355 4-bolt
I did punch it, but the rear end just went up in smoke. On the freeway, it was awesome. I'll be ready in 4 weeks.....maybe 3. Right now, I have absolutely NO desire to even look at a wrench, let alone twist one. The starter was set up foe 15x tooth flywheel. installed 168(?) tooth flexplate, so starter had to be moved. Now, it needs to be shimmed. So, I got THAT goin' for me............ LCA brackets going on, too. Also, gotta change the thermostat. Lower temp. 160. Are we having fun yet???
Old May 29, 2006 | 07:06 PM
Car: 1985 IROC
Engine: 355 4-bolt
I don't know. You're making a lot of torque, and it's hooked!!!!!
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
aharvel50
Sep 21, 2015 07:31 PM
89newfun
Sep 16, 2015 09:28 AM
