South Central Region Board for the states of Texas, Oklahoma, and Louisana.
The saga continues....
Old Nov 10, 2007 | 06:11 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
First off I want to say thanks to Mike(1bad91z) for give me the clutch hydraulics I needed to get my car driveable. I installed them tonight and just when I thought that everything was going my way I ran into another problem. I started the car and let it warm, and then I pushed the clutch pedal in and it started making a terrible whining sound. So I took my foot off and then pressed it again and of course the sound was there again. So I cut the car off and Pushed the clutch pedal down to see what was up and it felt like something was binding and not letting it push down all the way. I got under the car and played with the clutch for a little and the pedal felt better. So I went to start the car and when I turned the starter it made a sound like the starter was grinding with the flywheel. I am going to post in the transmission board to see if anyone can help me out, but it sounds like I need to pull my trans and get a new fork and re-install the TO bearing. I am not discouraged though, I will get-r-done. Thanks again Mike.
Old Nov 10, 2007 | 06:38 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Re: The saga continues....
You're welcome!
When you buy the new fork, DO NOT cheap out. What I mean by that is, buy a new TO bearing AND most importantly, a new pivot stud. You may have to get the pivot stud from the dealer if O'reilleys doesn't carry it.
The pivot stud get's worn over time which throws the whole thing out of allignment causing noise, vibration, etc...
You'd be surprised what a difference it will make if you replace all three components. Also, I don't know how good that slave cylinder is. It may be one of the sources of your problem. But, it may still be in working order.
Good luck!
Old Nov 10, 2007 | 07:45 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Thanks, I was planning on the new TO bearing and Fork, but didnt think about the pivot ball. I thought about the slave/master combo so I replaced both with the new ones I already had. I am still a little curious as to why the pedal felt like it was binding.
Old Nov 10, 2007 | 07:52 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Sorry to hear, but atleast you are not alone, just got the new clutch in from last weekends destruction, you know it doesnt take long, i think stock clutches are what keeps my T5 alive. Just really glad to see you arent giving up on it. ****, how you think i feel, i bought that brand new hood for it to just fly outta the back of my hood, i am picking up a stock flat glass hood tomorrow.
Old Nov 10, 2007 | 08:24 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Are you buying the hood from Daniel?
Old Nov 11, 2007 | 01:25 AM
Red92RS's Avatar
Car: 1992 Camaro RS
Not me.
Old Nov 11, 2007 | 03:04 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I have a guy giving me one like Daniels for free tomorrow. Needs a little glass work, but itll hold me till i get another L88 hood from VFN.
Old Nov 12, 2007 | 02:16 PM
ZONES's Avatar
Car: 90 camaro/86 ta
Engine: 305/350
Holy crap, my old user name still works!!! Man, 03...its been a while...
Your throw out bearing might have been sticking...
Old Nov 12, 2007 | 02:45 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Yeah, I am going to play with it some this weekend. The pushrod from my slave cylinder looks like its sitting kind of crooked in the clutch fork as well. We shall see, I am getting close though.
Old Nov 12, 2007 | 07:06 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Manuals.............. TOO MANY HEADACHES!!!!!!! Come over to the other side boys. A well-built 350 will handle anything you can throw at it.
Old Nov 12, 2007 | 09:05 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Yeah, standard trasmissions are much more complicated than autos, but more fun to drive as well. I cant stand how boring it is driving a powerful car with an automatic transmission. Long time no post Barry, whats up? You going to make it the winter meet?
Old Nov 13, 2007 | 04:20 PM
ZONES's Avatar
Engine: 305/350
Automatics.............TOO HEAVY!!!!!!!!
I only would go auto if it was a dedicated track car, but thats just me....or maybe when i get old, i just installed a front seal on my 94 GMC, man i would rather do my T5 in my maro any day!!!!
Old Nov 13, 2007 | 04:38 PM
Mr.Wolf's Avatar
Car: 87 Z28
Engine: uh does the name give u a hint
whats so complicated about a man trans, autos are the possible complicated ones, with all the different circuits, accumilators, valves, etc,.
Old Nov 13, 2007 | 05:07 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Yeah, but everything is inside. All you have to do is slip on the torque converter, bolt it up, and go (plus shifter cable and detent cable for some). You only start to run into problems when something fails. With the manual trans you have to install the pilot bushing, the flyweel, the clutch, the pressure plate, then you have to install the throwout bearing to the clutch fork, then the bell housing. AND FINALLY you get to bolt it up. Pain in the ****, but the driving is great.
Old Nov 13, 2007 | 07:06 PM
ZONES's Avatar
Engine: 305/350
Man, you sissapoint me, i live my T5, it is 75 LBS!!! My clutch set and plit bearing go together so easily. I have no issues with it flying together. My only complaint is for both atup and stick, my damn Y pipe, i have to cut it off to drop the trans. The heavy *** auto is a pain if you dont do it allot by yourself, might fall off the jack, might not. Then there are the trans jacks, i dont have one so it sucks to have a auto land on you if it fals off, i just pich my T5 up like it is nothing.
Old Nov 13, 2007 | 09:00 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Yeah, I forgot about that. I am just used to autos, easy money for me. I also like the fact that you dont have to worry about the trans cooler and the kickdown cable. I will take a standard any day. Auto is like kissing your sister.
Old Nov 14, 2007 | 01:11 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yeah, . Auto is like kissing your sister.
LOL Bwahhahaha, that is funny...
Old Nov 14, 2007 | 01:34 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I dunno, it depends.... Is she hot?
Old Nov 14, 2007 | 04:38 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
??? Do not have one...
Old Nov 14, 2007 | 10:38 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Not cool Mike, not cool.
Old Nov 14, 2007 | 11:31 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
lol
Old Nov 15, 2007 | 08:05 AM
IROCaholic's Avatar
Car: 89 Camaro RS
OK, so I pulled the dust cover off of the bell housing to inspect the fork, and some how the Throwout bearing has come off of the fork completely and is just sitting on the input shaft of the trans. I guess I installed it wrong. So I am going to pull the trans saturday and install a new fork, TO bearing assembly and hopefully I will have her back up soon.
Old Nov 16, 2007 | 04:32 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Good to know it is a little thing, i am amazed my T5 is holding so well.
Old Nov 17, 2007 | 04:44 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Got the trans out today and all I can say is WTF? The "fork" part of the clutch fork was bent on both sides and the throwout bearing looks like its been through a grinder. What the hell did I do? It looks like the throwout bearing was ripped right off of the fork with some tremendous force. I am ordering all the new parts tonight and I will install them next weekend. In the mean time I need to figure out what I did wrong so I dont do it again.
Old Nov 17, 2007 | 11:48 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Hell man, prolly old worn *** parts, is your T5 factory original??? Mine is, i need to replace those same parts but shoot, i just rather install the T56 and be done with it.
Old Nov 19, 2007 | 12:01 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Get a new pivot stud.
soul.justice
Car Audio
Jun 30, 2013 06:47 PM
xbmx89
35
Jan 23, 2013 09:17 PM
jhainer
Members Camaros
Jan 6, 2013 01:11 PM
snflupigus
Nov 23, 2010 01:13 PM
FruityOne
Apr 27, 2004 12:18 AM
