Who dips engine parts in houston?
Car: 1989 TA
Engine: 305, 5.0
i just got tpi injection at a swapmeet for like 50 bucks
and i'm looking for a place to get them cleaned up and put it in that chemical dip that makes it nice and clean (dont know what its called) any help would be appreciated
and i'm looking for a place to get them cleaned up and put it in that chemical dip that makes it nice and clean (dont know what its called) any help would be appreciated Moderator
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Who dips engine parts in houston?
You do, if you buy a drum of CRC Tyme-1 at the parts store.
Engine: 383 Carb
Transmission: 4L60
Not real cheap, but you can reuse it and it'll last you a lifetime.
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Westside machine in Houston (like most machine shops) has a heated parts washer that I think will do what you want. It is what they use to clean engine blocks, oil pans and other assorted nasty parts.
Engine: 383 Carb
Transmission: 4L60
The "hot tanks" for cleaning engine blocks use lye, except maybe in California where CARB makes them use magic pixie dust or something. The problem with lye is that it dissolves aluminum. For aluminum parts like your TPI, they shop would just put it in a tank of cold carb cleaner like you could do yourself.
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
