South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Heater control valve
Old Apr 28, 2009 | 06:27 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
I need a one, as i broke mine.. does any one have one handy? This is the black thing under the hood with 3 hose going to it..Thanks Jeff 713-298-2078
Old Apr 29, 2009 | 09:40 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Heater control valve
Not to be an ***-hat, but this is a readily available part (O'Reillys, etc.)
and to the best of my recollection a Jackson ought to cover it.
Old Apr 29, 2009 | 09:41 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Parts stores carry them and they aren't that expensive. That's one part that you would rather have brand new.......
Old Apr 29, 2009 | 10:39 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
I bought one today 18.00 new from the auto parts store, I'm not sure.. why i thought these were obsalete? Thanks, Jeff
Old Apr 29, 2009 | 11:04 PM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
What exactly does the "heater control valve" do anyway?
I don't think my car came with one.
Old Apr 30, 2009 | 07:39 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
I belive. under vacume, It opens a valve that alows hot coolent to flow to the heater core. my spelling sucks today
Old Apr 30, 2009 | 07:47 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
OK, that's what I thought also, just wasn't sure.
My '82 never had one.
Old May 20, 2009 | 12:22 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
how did yours do it? i would be interrested in getting rid of mine and going to a non valve system.
Old May 20, 2009 | 01:48 AM
MiScHiEf's Avatar
Car: 88 Formula
Engine: 305 TBI
https://www.thirdgen.org/forums/tbi/...up-your-3.html
Old May 20, 2009 | 07:03 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
The water always flows through the heater core. As long as the temp control is not set to "heat" the air doesn't flow over the heater core and does not get hot.
Well, it might heat up a little...but it isn't much.
Old May 20, 2009 | 02:42 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
My 85 never had one. Some say that the water always running through the heater core is better in the long run as it never has a chance to sit up and rust due to non-use,which down here is about 90% of the time.
Old May 20, 2009 | 03:48 PM
Car: 1990
Axle/Gears: stock
decided to do it when i pull the heads and redo the intakes and exhaust. im tired of all that rubber hose - and i have air so it does not actually get hot there.
i just want to clean things up and not have to deal with that 3 way valve.
i can always turn the heater off with a valve during summer if i want, but probably not.
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
New2Chevy
Sep 28, 2015 12:35 AM
lakeffect2
Aug 23, 2015 08:44 AM
