South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Will this fit my car?
Old Oct 31, 2013 | 05:31 PM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Hey guys, can any one tell me if this'll fit my 91 Camaro rs. It has a stock rear end.
http://bit.ly/1iyANTH
Old Nov 3, 2013 | 08:34 PM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Re: Will this fit my car?
I got 3.42 gears and a posi unit for my car. (91 Camaro rs with a 350 tbi) what can I expect in terms of performance after I install these parts. I know I won't get hp gains obviously. But how much will my acceleration increase? Thanks in advance.
Old Nov 10, 2013 | 12:28 PM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
What gear ratio do you have now?
Old Nov 10, 2013 | 03:55 PM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
My car has stock 2.73? But I ended up buying an eaton posi carrier and I'm gonna put 3.42 from that g80 carrier on it.
Old Nov 10, 2013 | 05:31 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
I would guess that the gears will make it feel about 20% faster. The posi won't do anything (straight line, dry road) unless you have a wheel spin issue.
Old Nov 10, 2013 | 05:37 PM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Oh ok. Thanks. I was also considering 3.73 but I thought it would be too low since my car is a daily and I do a lot if highway driving.
Old Nov 10, 2013 | 07:07 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
"Conventional" wisdom is that a 3.73 is as low as you would want to go on a daily driver with overdrive. If you do a lot of highway driving you probably made the right choice.
Old Nov 11, 2013 | 12:57 AM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Thanks for the info. Maybe you can help me with this question as well. Are vortec heads a direct swap to a 350? I know the intake needs to be changed but will everything else fit? I tried searching the forums but didn't find much. Actually, are vortec heads worth swapping? Performance wise? This car is my daily driver and I'm looking to get a little more power out of it.
Old Nov 11, 2013 | 03:02 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
I THINK that vortec heads/intake are a direct swap for a 350. I'm not sure about a 305...there may be valve clearance issues...but I don't know for sure.
Old Nov 11, 2013 | 04:06 PM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Oh ok. Thanks again. I got a 350 in the car and am looking to swap to the vortec heads.
Old Nov 11, 2013 | 07:34 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
The vortec heads do make a little difference,
but there are a lot of choices when it comes to cylinder heads now a days.
As far as your rear axle gearing.
I had a 2.73, went to a 3.73 limited slip, then down to a 3.42.
The 2.73 gives you great gas mileage
The 3.73 made it a spirited 305 4bbl
The 3.42 does a little of both.
If I had to choose, i would choose the 3.42.
I was happiest with it.
Old Nov 11, 2013 | 08:43 PM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
What kind of heads would you reccomend? I bought a edelbrock 3702 cam which I know didn't have too much lift, but I also got some 1.6 rockers to make up for that. But then I was thinking i can open the valves all I want and it won't make a difference if the heads don't flow. I got an 87 350 tbi, headers a bigger bore tbi(though I'm not sure of bore size)
Old Nov 12, 2013 | 05:43 PM
Axle/Gears: unknown
What exactly do you want out of your engine?
1.6 rockers on what CC heads with what size valves (vortec or not)
and with what compression pistons
with your 3702 cam, may not all match up?
Headers or stock exhaust? If headers, what size? 1 5/8 or 1 3/4?
What size TBI?
Too often do I see someone not "match up" items on their engine.
As an example, someone I know has a 69 Camaro.
Years ago he built the engine with this large carb and cam and heads.
It sounded good and was powerful.
Within the last 3 years he put a smaller cam and carb,
but his car became quicker and seemed to have more power!
Nothing was matched before. He was always burning rich as well.
he later changed his stall torque converter to a much smaller one.
He nows does not dread stop and go traffic.
All these things factor in.
Old Nov 12, 2013 | 09:18 PM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Thanks for the info. I'd like to run 12's if that helps. And I'm not saying the parts I've listed will get me there. At the moment I'm just getting parts that will still be useable in a 383, because that's what I ultimately plan on doing. My headers are 1 5/8 I think. Tbi is 670 cfm.
Also I chose the 3702 cam because the engine wouldn't need a tune. But then I decided I will toon the engine.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
armybyrd
Aug 10, 2015 09:23 PM
