South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Help getting my thirdgen running
Old May 11, 2015 | 08:40 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Hey guys looking for someone who can help me get my car running. I'm in Houston. Willing to pay. I just recently swapped In an lb9 from a 90 Iroc along with all the wiring and ecm. It cranks but will not run. I have no injector pulse and can't figure out why. PM me or post in this thread. Thanks -Luis
Old May 11, 2015 | 09:43 PM
bmoore7402's Avatar
Car: 1990 Chevy camaro rs
Transmission: 700 r14
Axle/Gears: not sure
Re: Help getting my thirdgen running
Make sure wires aren't crossed, test which wires have power and make sure engine has ground power
Old May 12, 2015 | 02:32 AM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Most likely culprits are bad/not enough grounds on the ECM and engine, bad ignition control module, bad ECM, or no signal from ECM to ignition control module. Check continuity between the top of your plenum and the chassis, it should be close to or below 1 ohm. Also check for spark while cranking.
This problem rears up from time to time in the forums, I did a basic google search and came up with tons of threads on Thirdgen about it. Also;
http://www.camaros.net/forums/showthread.php?t=153617
Old May 15, 2015 | 11:58 AM
Dark Ember's Avatar
Car: 90' Firebird Formula 350
I had a similar problem with a TBI S-10. It was a faulty ignition module. I dont know about 3rd gen wiring but on an S-10 the Ignition module had to send a 5 volt refrence out and if it doesnt send that, then the injectors would not fire. It was not easy to find that one. But before you spend a lot of time on this possibility, I give 1983 chimaera a X2. Check on these forums first.
Old May 15, 2015 | 05:55 PM
Lmancha96's Avatar
Engine: LB9|TPI
I discovered my problem yesterday.
I decided to open up the ecm to see if it had some kind of damage done to it and the first thing I see is my prom out of the socket. So I insert that in there correctly and finally I have pulse again. I guess somehow it came out.
Anyways I appreciate all of the input guys. I hope to see all of you at this years THIRDGEN round up!
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
