TPI mechanic in the Houston area
I'm all out of ideas on this car. Car will start but will not stay on if I let off the gas. Had new distributor, plugs, air control valve and steel nothing.
This is what I do know about the car.
Previous owner replaced 305 with 350.( Not sure if 305 exam is still in the car or he swap to a 350 ecm or if that even makes a difference.)
LT4 hot cam.
Vortex heads.
Chip
LT4 hot cam.
Vortex heads.
Chip
Re: TPI mechanic in the Houston area
would you still happen to have the old 305 ?
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I'm by no means an expert but;
Have you tested your throttle position sensor?
Could your EGR valve be sticking?
Have you looked at your base timing?
Clogged injectors?
Is your ECM throwing any codes?
Will it drive at all (if you keep in the gas)? In other words will it make any power off of idle?
Clogged injectors?
MeenZ28
Southern California Area
11-14-2015 01:10 PM
litemupp
08-23-2015 10:09 PM
89IROCZZ4
South Central Region
02-15-2012 08:27 PM
