FS DART 230 cc heads
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have a set of ported dart 230cc heads, pro 1 aluminum, 2.08/1.60 valves, big springs. About 150 miles since refreshing, going to another setup so i need to sell for funds, 7/16 studs, 1000$ as is, 1100$ with 1.5/1.6 crower roller rocker combo.
zones89rs@yahoo.com
zones89rs@yahoo.com
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Re: FS DART 230 cc heads
Pics to bobby_stipkovic@comcast.net? What kind of setup were you running with these?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Engine was/is a .030 350, stroker crank, 6.0 I beams, forged flat tops 383, hyd roller 242/252 @.050, .542.565 lift on a 112 LSA, Perf RPM air gap, holly 750 carb, hooker supercomps. 1.5 exh/1.6 int rocker ratio. Ran STRONG as all hell to 7000 RPM, but my dumb *** used EVERYTHING new but the damn cmashaft, it looked a bit rough and chewed up the cam bearings. SO, i pulled it and it has been sitting and i am not going to be using it. I painted the heads cast iron color to fool the street crowd, i will have pics when i get home from work today. Would sell the short block too.
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
