South East Region Regional Board for South East Members.
tach problem
Old Feb 11, 2007 | 10:04 PM
mattmerritt89's Avatar
Car: 1987 Camaro
Axle/Gears: 4.56
tach problem
I have a 91' camaro rs 3.1 the problem I'm haveing is when I start my car the tach pegs out and stays therer till I cut my car off. Does any one what I can do to fix this problem.
b
Last edited by mattmerritt89; Feb 11, 2007 at 10:06 PM. Reason: Automerged Doublepost
Old Mar 20, 2007 | 06:53 AM
1991Camaroz28's Avatar
Car: 91 Z28
Transmission: TH700-R4
i have a 91 taht had a similar problem. it's the chip in the back of the guage cluster that is bad. there is a common problem with the black and white IC on it. try getting one from the junk yard. if that doesnt make it work then i recommend reading this thread. https://www.thirdgen.org/forums/elec...ter-fix-2.html It has the info you need to fix it yourself. also the spare chip from the junkyard should make good practice soldering if it is fired too.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
