454 tbi
454 tbi
anyone know where i can get a used 454 tbi in the phoenix area. i am thinking about using one on my 350 rebuild going in my truck. i currently have the 305 and would like to step up the injection on my new engine. thanks
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Re: 454 tbi
i am putting world product torquer II heads on. i think ill use a comp cam 304-8 (210/220 @ .05 , .500/.51 lift , 114 deg lsa). and im not sure about a manifold yet. i need an egr set up to pass emisions here. would a carb manifold with an adapter be a better choice than the edelbrock tbi performer?
90_WS6_Formula: what is a fair offer? im not tryin to lowball you. i really dont know anything about these tbi's. maybe they cost more than it is worth for my set up and just tbi mods to my 305 tbi is enough. any advice would be appreciated. thanks
for one I'd make sure that the springs on the heads would handle that much lift. I have a set of world product torquer sr 305 heads and they will only go to .500 lift.
What you want to do is set a realistic goal of where you want to be as far as output goes. Then build your engine accordingly. You can blindly go on modding an engine and it still wouldn't be as strong as a well planned engine.
The stock TB will support around 275 HP with a better fuel pump and of course as Chris pointed out an adjustable pressure regulator. You can either make one adjustable or purchase an aftermarket part.
As far as the 454 TBI goes I'm putting it in an Ebay auction with a 7525 Weiland Single plane intake that's EGR compatible, and the adapter plate.
Almost any aftermarket intake will be better than the Edelbrock TBI intake. It's simply a bolt on replacement for the stock intake that offers some performance improvements.
Bruce... for $3 I'll let you look at it.
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Originally posted by 90_WS6_Formula
...Bruce... for $3 I'll let you look at it.
... Thread
