Can anyone in Phx Metro help me with burning?
Car: 1994 Trans Am
I can supply the chips but that is it. I don't have a PC or the money to buy one for a once or twice chip burn. I asked Synapsis but I think he needs me to supply with the programs and the modified programs which I can not.
I can get a SD-L98 chip and a blank chip, but I need someone else to help with the actual burning. Please help me.....I'm pathetic
Car: Sexy
Engine: Stock
Transmission: Slipping
All you need is the blank. You can get the chip images from .http://www.moates.net/fileman/.
I know there's gotta be *someone* in Phoenix who burns chips.
Car: 1988 IROC
Engine: 350CI
Axle/Gears: 9 bolt 3:70
I can help you out with that. Do you have a 350 or 305 memcal now? Is this for a stock configuration. If this is for your 91 then you still want the vats enabled? Give me more details on what you are looking for.
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
I could use some serious help with a newly built motor and a chip...Have nothing though...no chips, memcal, or anything....Will buy chips needed or whatever and willing to pay for help.
Car: 1994 Trans Am
Please let me know.
-Thanks!!
Car: 1988 IROC
Engine: 350CI
Originally posted by BigWhiteGTP
I have the stock 305 SD chip, I NEED a chip for a 350, but with 19lb injectors. Can you do that? I don't need to much done other than that. Why I want it that simple, I've seen the differences between the 350 chip and 305 and it's like night and day. Different timing, tq conv lock up rpm, fuel, etc.....
Please let me know.
-Thanks!!
Please let me know.
-Thanks!!
Car: 1994 Trans Am
I'm confused about the limp home mode, if it's in the 350 program, shouldn't it be transfered over as well?
And my car is my daily driver.
Also someone on here said they can give me their stock 350 chip, would that help things or no?
Thanks for the help, I appreciate it greatly!
-Kevin
-Kevin
Car: Sexy
Engine: Stock
Limp home mode is done in a resistor network. It's hard "coded" into the memcal. If you take the blue cover off your memcal you can see the black prom chip and then the network next to it.
Car: 1988 IROC
Engine: 350CI
Car: 1994 Trans Am
I'm assuming he's selling me the memcal, not anything I'll have to solder. The memcal is what I want right, the thing I can simply snap in and go, right?
Car: 1988 IROC
Engine: 350CI
Car: 1988 IROC
Engine: 350CI
You can reprogram the stock memcal or should I buy a blank?
Car: 1994 Trans Am
Someone will sell me their 24Lb LT1 injectors for $80 shipped and the guy is selling me the 350SD memcal for $30 shipped. Is this a good deal? I think so but I have been wrong before.
Or should I deal with the burning, buying a blank chip, getting is soldered on, and then buying an AFPR and installing a gauge?
What should I do? I think the 1st choice is the easiest for both me and you z28Iroc
. Junior Member
Car: 1988 IROC
Engine: 350CI
. If you want to buy a chip and socket, I can probably help you out with that and the reprograming.
Glowsock
Sep 11, 2015 11:09 PM
