disconnecting power antenna
does anyone know how to disconnect the power antennas in our cars. the gears broke in mine and the motor is killin my battery. other than just pulling the fuse (which in turn kills all my pwer options) what other way is there to kill power to the antenna?
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Right behind the valance (you know that little one right below the map pocket) Pull that off and there is a silver relay that has two connectors....One goes to the radio the other goes to the Antenna....Disconnecting either will shut it down
sailtexas186548
Aug 24, 2015 10:11 PM
