South West Region South West regional discussion board.
Scientific Tuning
Old Feb 10, 2006 | 05:02 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Scientific Tuning
I failed emissions... again. I was wondering if it was possible I had a clogged injector fattening up one of the cylinders after all the lines I redid. One of the methods NHRA Top Fuel funny cars use to measure cylinder to cylinder fuel usage is to take the temperature of the header primaries. I just happen to know someone with an infared camera, so we went out and did all the primaries in one shot.
What did I find? Nothing. The biggest difference I found in primary temperature was about 20 degrees F, and that was from the wind blowing over the exposed #1 primary. Here's a pic of the #3/#5 primaries. (The IR camera we used doesn't have very high resolution.)
The headers were all around 450 degrees F. This is at idle, coolant temp up to 197F. The fans kept turn on and off and screwing with the readings, plus the windy day didn't help.
When we were done I thought it'd be cool to take a couple full engine pics. The camera doesn't have a very big field of view since it's meant to look for cracks in tanks and such, but I still like the pics.
Driver's side:
Passenger's side:
Old Feb 10, 2006 | 09:15 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
oooo, cool toy
Old Feb 11, 2006 | 08:18 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Has whatever is causing the emissions failure been isolated to a particular area? Is it related to the lower temps that E85 operates at?
Old Feb 12, 2006 | 06:46 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
That's pretty cool man!
Old Feb 13, 2006 | 11:11 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Not yet. I've just been tuning the chip for so long without success I was wondering if there was an actual equipment problem I might've missed. (It's easy to forget the hardware.) I put in hotter plugs and bumped the timing a little bit to try and heat up the combustion some more. That didn't change much either. I actually have the car to the same readings I had last year with gasoline, when I moved the timing a bit and lowered fuel pressure (in the parking lot) to pass. I'm trying to get it to pass on the chip only so I can just load "emissions.bin" into the Osterich, pass, then load "*** kicking chip.bin" in the parking lot and take off.
I know a guy with a dyno and an exhaust gas analyzer that told me I could head over and tune the car there. I just haven't had time (or cash) lately, it's all been going into the 31.
Old Feb 15, 2006 | 10:36 PM
ChainHartMachin's Avatar
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Transmission: 4L60E /700R4
Axle/Gears: 10 bolt 3.73 / 9bolt 3.27
I'm curious... the link in your sig says your car has an HSR, which does not have provisions for an EGR valve (as far as I've ever read anyway).
I'm more or less wondering how you address this particular issue at emissions testing?
Old Feb 15, 2006 | 10:43 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
They don't ask. They only care about the AIR system, the gas cap, and the cats. I've passed with it two years.
Old Feb 15, 2006 | 10:49 PM
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Ahh... I figured it was either that, swap back to stock TPI or perhaps fabricate an external EGR system like I've seen on some late model trucks.
AIR system though? Blech... I hate that crap... it was one of the first things to go when I decided to move to Flag... where there is no smog testing.
Old Feb 16, 2006 | 12:25 AM
Cpt. Blasto's Avatar
Car: 1988 Trans Am GTA
Are the paramaters that you fail in emissions such that functional catalytic converters would help?
Old Feb 16, 2006 | 01:53 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Yup. And they're functional. The cats literally have about 100 miles on them, the AIR system is fully functional as well.
I'm registered out of county now, so they're all sitting in a box on the shelf.
Old Feb 16, 2006 | 11:05 AM
Man, I thought one of the benefits of e85 was better emissions, less polutant.
Old Feb 16, 2006 | 12:34 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
The main benefit is domestic production and less dependency on oil reserves. E85 can produce bad emissions just like gasoline.
The exhaust from my car smells like a drunk man's breath. I keep expecting to get pulled over for DUI or something.
Old Feb 16, 2006 | 05:32 PM
Obviously the concept of a renewable energy resource that is not controlled by hostile nationalities is the biggest benefit. But somehow I got under the impression that it was cleaner than gasoline.
Yeah the police will be seriously suprised when the find they can smell your breath from outside, but can pass the field sobriety test
Zell1luk
Sep 29, 2015 10:36 AM
