I'm back to a 305, 638 does not mean 350.
Car: 1994 Trans Am
So I am removing the head on my T/A and I get it off, grab a ruler and measure the bore size. 3.75 inches....hmmm? Now that there isn't any wires in the way I take a rag and wipe off the cast numbers on the back of the block...sure enough 5.0L. Well, what that means is that for the last 6 months I thought I had a 350 because some bonehead says in a block identifying thread said "if the motor has the 638 on the underside it means 350". Well, some of you may know that would be false but I searched and searched and found no info to back that up or prove it wrong. So 350 I thought I had which makes sense why I am beating cars a 5.0 shouldn't. I'm talking G35's, Z's, hanging with my bro's modded GTP which does low 13's.
Now with that 350 thinking I bought some 350 things, heads from Schwartz, injectors off of Tiresmokin', 350memcal from TPIparts, and most importantly a $125 350 gasket set from autozone. I'm sure I can swap it, but I ordered it 2 days ago, and now I will have to wait another 2-3 days to get the right one.
Anyway, end of rant. Give me your thoughts.
Car: 1994 Trans Am
No Vin is for the Lb9. The last owner said the previous owner put new head gaskets in. The previous owner put in a new radiator. It's strong. Really strong for a 305.
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
should of pulled a head to figure out for sure anyway. but owell
Car: 1994 Trans Am
Well I wasn't gonna pull the whole engine apart just to find out and then put it all back together. Why I opened it all up now is because I blew a head gasket. I would never do this for fun. I've been working on this thing for almost 15 hours and I still don't even have the passenger head off yet.
15hrs!! get a book man! thats a long time for just one head! lol but keep at it
Car: 1994 Trans Am
I think putting it back together will go much faster. I'm just taking my time so I don't break anything. I need to buy a 90* brass bend for the driver AIR tube. I'm also cleaning the hell out of this thing. It's all covered in rusty coolant and grease. I will also touch up scratches as well.
Anyone have any RUNNER straightener *****? Mine are all dented up. Thinking of taking them to a music shop. They repair dents to horn instruments all the time I'm sure.
Car: 1994 Trans Am
The engine is back together and cleaner than it has been in probably 10 years. Problem is it won't start. Tony C is on his way over as we speak to see if he can work some magic. Wish us luck.
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Transmission: 4L60E /700R4
Axle/Gears: 10 bolt 3.73 / 9bolt 3.27
Good luck.
My engine was pretty filthy when I tore it down. There were nice sludge chunks in the lifter valley that reminded me of burned pancake pieces.
(just finished my HSR install a few hours ago)
Fast355
Dec 2, 2016 06:33 PM
