South West Region South West regional discussion board.
Help in Tucson
Old Jan 13, 2008 | 11:33 AM
SKNeverNights's Avatar
Help in Tucson
Hi, My name is Craig Marshall and I live in Tucson. I manufacture an electrical harness product for C3 Corvettes which is sold by Speed Direct and Ecklers. I would like to provide a product for 3rd gen f-bodies and what I am looking for is someone local here to the Tucson area with a stock 3rd gen that I can use to build a prototype harness. It would involve only an hour or so of measuring and pictures and in return, you would get you a free production harness for your car. Knowledge of the various year and model (camaro/firebird) differences would be extremely helpful. If multiple harnesses are required to cover these differences, then a production harness will be provided for each. The Corvette harnesses sell for over $200.00 each.
Thanks,
Craig Marshall
SK Products
SK_Products@***.net
Old Jan 13, 2008 | 12:53 PM
92WhiteZ28's Avatar
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
Re: Help in Tucson
im pretty sure the harnesses are different for the carburated/fuel injected cars. i think they changed the harness after 87 also.
Old Jan 18, 2008 | 02:22 AM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Re: Help in Tucson
PM sent!
Old Jan 20, 2008 | 11:21 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: Help in Tucson
I got a stock IROC-Z, 5.7 TPI. '87. I've had to repair the harness, but I used stock replacement stuff with the correct wire colors, so it shouldn't be an issue. I also have an electrical diagnosis manual for this car that lists a circuit view of everything. Let me know.
And I think there'd be more wires for a Firebird, pop up headlights and the like. Under hood for one of those is crazy busy. So glad I have a Camaro. :P
Old Jan 20, 2008 | 03:24 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
Re: Help in Tucson
I got an 89 5.7 TPI Trans am you can look at I think it would be very similar to TheScaryOne's camaro. But if you want to see if there is a difference between them you can. I think 90 or 91 they changed to from MAF to MAP sensors.
Old Jan 21, 2008 | 02:39 PM
Beater79TA's Avatar
Re: Help in Tucson
If you want to drive up to Phoenix, you can measure and photograph a broad spectrum of wiring options. Including a 1982 Z28 for the lower tech carb option. A 1990 IROC with the 305 TPI for the later Camaro options. And a 1988 GTA (with digital dash) for one of the more complicated Firebird options. I'd offer up a 1992 TBI Camaro but we pulled the motor and harness in it last weekend.
Old Jan 24, 2008 | 03:36 PM
Re: Help in Tucson
Thanks everyone for all the great offers of help. I'm sorry for the delay in responding as the Wife's Sister passed away this week and things are not back to normal yet.
To clarify, the harness is a plug-n-play harness that includes an 8 guage feed to relays that provide 14 volts at up to 480 watts to the headlight system. The design goal for this harness, as was the Corvette harness, is to be able to install the product with no modifications to the present wiring.
(here is a link to the Speed Direct ad)
http://cmc.speeddirect.com/AMAZING/c...K503%2D125&eq=
Again, thanks for the responses and I should be back to things by the middle of next week.
BTW: I'm a GM guy from way back - This is under the hood of my 72 Corvette resto/mod. It's a ZZ4 with a H.O.T. cam w/1.6 rockers and edelbrock heads and fuel injection.
Craig
SK Products
SK_Products@***.net
Old Jan 31, 2008 | 08:18 PM
aperfectcircle's Avatar
Car: 91 Camaro
Transmission: 700 r4
Axle/Gears: stock, soon to change.
Re: Help in Tucson
i have a stock 91 camaro TBI you can gander at
75bike
Sep 20, 2015 09:37 PM
Veaceonee
South West Region
Sep 6, 2015 10:04 PM
CraZ-28
South West Region
40
Aug 18, 2010 01:57 PM
CraZ-28
South West Region
74
Nov 15, 2003 04:17 AM
camaro-mayhem
South West Region
Aug 5, 2002 01:48 AM
