TPI setup for sale Tucson
Car: 1987 Camaro Iroc-Z
Engine: 5.7L 350 TPI
Transmission: Manual Valve body TH 350
Tuned Port Injection system nearly complete for sbc 305 or 350 setup. came off of a 1987 i-roc z28 camaro, has one small dent in the runners and the wiring harness is missing a few pigtails due to pack rats but you can get all the pigtails that are missing individually at some websites i can list if you decide to pick it up. System comes with the following:TPI base, runners, and plenum, throttle body, egr valve, all engine relays, original fuel pump(still worked fine when pulled puts out 45psi), fuel rails with 19lb injectors(they look aftermarket possibly 22lb) and fuel pressure regulator, steel fuel lines to connect from engine to body, mass airflow sensor and dual intake air box lid/base and upper radiator/hose support, also have ECM and prom for 305 if your ging 350 all you would need is a new prom which you can get at autozone or make your own and possibly new injectors if they do end up being 19lb. this is going to be the most complete kit minus a full harness that you will find for the same price or less as the rest of them. email me if you have any questions i have quite a bit of experience with this setup this came out of my 6th camaro.
Re: TPI setup for sale Tucson
was for 250 sold it yesterday sorry
evilstuie
01-09-2020 08:29 PM
Sanjay
08-12-2015 03:41 PM
