South West Region South West regional discussion board.
i help you with az emissions
Old Dec 7, 2012 | 10:38 PM
  #51
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
Re: i help you with az emissions
Originally Posted by jmd
The last time I reset an OBD-II vehicle after an evaporative system part replacement, I drove just over 100 miles (because I wanted to and because I didn't want to deal with going to test twice.) It passed fine then. It's not a set distance; it's a number of factors affecting whether the PCM is "ready." But 100mi. should do it for sure.
As far as helping you, the original poster of this thread doesn't understand emissions laws, so good luck with that.
Have you ever worked for ADAQ?
Old Dec 7, 2012 | 11:05 PM
  #52
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Your question is not relevant.
What someone can "get by with" doesn't equal what the laws are.
I'm already aware of the significantly slack visual inspection now compared to years back. No one gives a crap about the AIR system in my car (it's there, but not 100%) or the EFE TVS in the t-stat housing. not being hooked up to anything. No one tests EGR valves by lifting the diaphragm.
Did you want to play a particular card in this game or would you like to concede that the inspection station in AZ don't fully enforce emissions laws per federal and state law? Because that's a fact.
Opening up a discussion with someone and trying to set yourself up as an authority of some sort while at the same time posting you can illegally get them tags doesn't help your case.
Old Dec 7, 2012 | 11:12 PM
  #53
mr305's Avatar
Car: 91' RS
I didn't ask for your life story lol it was literately just a question.
And nobody asked you if they're illegal so you comment is not relevant.
Old Dec 8, 2012 | 12:01 AM
  #54
gonzalesjon1990's Avatar
can you please email me everyone here wants to fight eachother thx gonzalesjon@gmail.com
Old Dec 8, 2012 | 12:05 AM
  #55
im just looking for help i bought my first car and was reading a little into the laws and read about it being waived but 450 alot and need my car to work, i will reset pcm again and see if it fixes the problem.
Old Dec 14, 2012 | 06:38 PM
  #56
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Engine: 1992 5.7L TPI
Threadjack...maybe. Was searching for help with emissions..... Az ironically and found this thread...from 2009, looks like it was just brought back to life.
I failed today. HC wasnt too bad, nothing cap-rotor-coil-wires-plugs wont fix....I hope.
I CO was off the fuggin' chart! Standard is 40.....I hit 100.25. Yeah, I knew I was rich but wtf?
Suggestions on where to start?
Stock 92' TPI + Headers, sits in a 87' K5.
Old Dec 15, 2012 | 09:47 AM
  #57
Has mr305 helped you yet? He has been good at helping
Me.
Old Dec 15, 2012 | 09:55 AM
  #58
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Yes, we spoke biefly.
Old Dec 18, 2012 | 09:02 PM
  #59
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
How new are your fuel injectors? Wonder if you have some leaking.
How is the compression? Timing to far Retarded?
Old Dec 18, 2012 | 09:36 PM
  #60
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Heres the report...
Injectors and timing need to be tested, Im unsure at this point but suspect one of those two.
I have the following parts to install, 1) as a matter of routine maint. 2) piece of mind in knowing they are new:
MSD cap-rotor-coil-wires, plugs (will check comp) TPS-MAP sensors (all other are < 6mos old), T'stat, valve cover gaskets (they are leaky) will do oil-filter change, clean or replace KnN air filter. For what its worth I had also planned a CS144 swap at this time too.
After all that I will retest and go from there, but I do suspect the injectors.
What is stock size 19#?
Old Dec 20, 2012 | 12:37 PM
  #61
Beater79TA's Avatar
Stock for a 350 is 22#. Stock 305 is 19#. Using anything else will require tuning tables to be changed.
Old Dec 20, 2012 | 12:52 PM
  #62
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Southbayinjectors has some nice bosch 3's. Are you running a heated 02 with those headers and have you confirmed closed loop operation. The air pump can easily be taken out of the eprom /memcal programing but I don't believe this is your issue at all.
http://www.southbayfuelinjectors.com...7&product=1502
Old Oct 24, 2014 | 09:52 PM
  #63
Gritz-n-Gravy's Avatar
Car: 1987 trans am
Engine: 305ci v8
Transmission: t5
Axle/Gears: 10 bolt 3.56
do you still work at m12?
Old Oct 24, 2014 | 09:54 PM
  #64
phoenixxx602's Avatar
Car: 1986 z28
Axle/Gears: 3:73
No
Old Jun 16, 2017 | 12:47 PM
  #65
Sleeper87's Avatar
Originally Posted by phoenixxx602
iv worked for ADEQ for 3years i kno what im talking about.. im not here to "mess with texas" im just helping my az 3rdgeners by showing the truth.. i dont know why you care so much anyway if your from texas
I bought my 87 with a engine swap already doNE on it, 75 was my hydrocarbon result and I also failed carbon monoxide by a little too
Old Jun 19, 2017 | 12:47 PM
  #66
Beater79TA's Avatar
You'll need to provide a lot more information than this to get any type of help.
What engine swap? Fuel injected or carb? Exhaust setup? Catalytic convertors? How was it tuned?
Old Jun 20, 2017 | 02:10 AM
  #67
Sleeper87's Avatar
305 to 350, edelbrock carb, catback/flowmasters, 1 cat, as far as tuning I don't know. I put a edelbrock performer rpm intake. New mini air cleaner and tons of replacement parts. Hei distributor.
Old Jun 20, 2017 | 05:35 AM
  #68
Beater79TA's Avatar
Sounds like a professional needs to adjust the carb to get fueling corrected. It might also need a new catalytic convertor. Depending on the cam in the 350 you might not be able to get it to pass though.
If this isn't your primary car, you could just put it on collector car insurance and not test it at all.
Old Jun 29, 2017 | 03:18 PM
  #69
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
No
do you still work for emissions? and if so, what station, and are you still doing what you did in '09?
Old Feb 3, 2018 | 08:58 PM
  #70
irocrocks1234's Avatar
Car: 1986 IROC.(RPO B4Z)
Originally Posted by old Phart
I don't have to pass emission tests in the Phoenix area because I have a waiver for having proof of collector car insurance. Sure does take care of that problem.
How do you get collector car insurance? Who offers it and what is cost?
Old Feb 3, 2018 | 09:03 PM
  #71
Beater79TA's Avatar
Most insurance companies offer a limited use collector car policy. The rules almost always include, 1) it can't be your daily 2) it must be garage kept 3) you have to have at least 1 other car as your primary that is not insured as a limited use collector car. Some will put limits on annual mileage. Some don't. It is an agreed value policy so the more coverage you ask for, the more expensive it will be and the more proof of value you will need to provide. But the insurance company will provide proof of this type of policy to the state and the vehicle will be exempt from emissions at that point.
Old Aug 15, 2023 | 06:20 PM
  #72
Mahollowman's Avatar
iv worked at AZ emissions station M12 for a long time and i see lots of guys talking about air pumps...... in az you DO NOT need air pump to pass visual inspection on cars newer than 1980 and less than 8500lbs..... so all third gens do not need air pumps to pass VISUAL!!!! but it may harm the smog test(runnin of the car)
I'm mainly wanting to know how to go about putting a different size engine in my car. I have a 5.0 mountaineer drivetrain and computer and willing to keep all emissions equipment, but want to install it in my Mazda Protégé 5.. I don't want to have to register it out outside of Phoenix just to bypass emissions. Is there any Kit car regulations that can be utilized? Are Kit cars like the Factory5 line that used LS and other plaforms register able here in AZ and wouldn't my situation be similar?
Old Aug 15, 2023 | 07:49 PM
  #73
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
You should ask your question on a Mazda forum...
Old Aug 15, 2023 | 10:57 PM
  #74
Well, this was just a general emissions question I had and this forum came up in the google search. Regardless of what vehicle I have, this post had info I was interested in since I live in AZ. The chance of me finding this person making the same post in the Mazda group would be almost zero. If my question violates the rules, let me know and I will delete it. Just so you know, If I had my choice , I would trade my crappy 5.0 and Mazda for an F-body and LS...Unfortunately, Finding someone to make that trade would be almost Zero also!!
Old Aug 15, 2023 | 11:29 PM
  #75
T.L.'s Avatar
I'm sure it can be done, but I'd be surprised if anyone here knows what emission controls are required for the year and make of your car to be in compliance...
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
