South West Region South West regional discussion board.
160 tstats rule
Old 08-02-2010, 04:38 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
160 tstats rule
Forgot how well they work. Anyway, just thought Id share that I installed one. Now the car runs cooler and got some power back.
Also, trans starts off in 2nd gear, or shift into 2nd gear waaaay too soon. So that partly explains the no spin, bogging 15.1@90 run a few months back. The other part of that run was the non shifting into 3rd.
Anyway, wanted to share
Old 08-04-2010, 12:32 AM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
Re: 160 tstats rule
yeah it really sucks having a car with no grill in the desert. I put a 160 t stat in my GTA last month as well and the temp stays under 200 as long as I dont get stuck in traffic. I have a hypertech thermomaster chip as well that makes the driver fan come on earlier. I notice all the time the car bogs down once it gets over 210. It LOVES sitting at 180-190! I am going to get a fan switch as well to make the 2nd fan come on earlier too.
Old 08-09-2010, 04:44 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: 160 tstats rule
thats my hang up with this state, its too damn hot under the hood in traffic, i dont drive from like 3 til 7 except down the street, its too hot, i put a 160* in and it did good for a while but it ran around 180* swapping it was a definite improvment over the 220* i was running
Old 08-19-2010, 01:28 PM
LWCS561's Avatar
Re: 160 tstats rule
how difficult is it to change on a third gen? I replaced the water pump on my car the other day, and now the temperature is going up, so im guessing my t stat is goin bad. And do any of you guys belong to a local club around az? other than azfba?
Old 08-19-2010, 01:42 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: 160 tstats rule
its really easy,make surte your cooling system isnt under pressure, unscrew the 2 bolts on the water neck, break the seal, bend it outta the way, replace the tstat and put it all back, just put a new gasket on the housing, theyre like 2 bucks at checker
Old 08-19-2010, 01:56 PM
LWCS561's Avatar
Re: 160 tstats rule
oh ok. i was trying to research in the forums and people were talkin about taking plenums off and throttle bodies off. i was like wtf? i just havent done one on a third gen before
Old 08-19-2010, 03:16 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 160 tstats rule
http://www.carnut.com/ramblin/_cool3.html
Mark_ZZ3
05-24-2018 01:02 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
88SS6SPEED
11-11-2015 07:05 AM
tommy z-28
10-06-2015 10:58 PM
86IROC112
09-11-2015 04:04 PM
Quick Reply: 160 tstats rule
