South West Region South West regional discussion board.
CRUISE ON CENTRAL!!!
Old Feb 7, 2011 | 12:15 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
ANYBODY KNOW WHEN ITS HAPPENING THIS YEAR???
Old Feb 7, 2011 | 05:05 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: CRUISE ON CENTRAL!!!
Last I heard it was in early April.... Still trying to nail down the date. Should know in a couple hours.
Old Feb 8, 2011 | 09:54 AM
mr305's Avatar
Car: 91' RS
Sweet thanks !!
Old Feb 8, 2011 | 09:57 AM
mr305's Avatar
Car: 91' RS
Do you still have the hook up on the T56's?
Old Feb 8, 2011 | 11:19 PM
Yup! Can get LS-1, LS-2 and LS-3 motors as well
Old Feb 10, 2011 | 09:36 AM
mr305's Avatar
Car: 91' RS
Nice nice haha i got my 5.3 complete for $450 pan to manifold with accesories all i need is a LS1 pan and a 6 speed
Old Feb 10, 2011 | 07:23 PM
91FirebirdAlex's Avatar
Car: 1991 Pontiac Firebird
Engine: Carbed LQ4 6.0
Transmission: blew trans up....T56 on the way
Axle/Gears: 9 bolt 3:45's >:)
WEEEE!!!!!!!
Old Feb 11, 2011 | 12:13 AM
Ah, I know what you mean! The pans can be hard to come by! The guy I know sold all of his.
Old Feb 15, 2011 | 08:33 AM
Scootermunch's Avatar
Car: 1989 Trans am GTA
hell yeah! whattup arizona!?! i'm in on this central cruise for sure! i was cruisin up there the other day with the t tops off and sporting the burt reynolds cowboy hat. got a few good stares.
Old Feb 15, 2011 | 09:04 PM
Could have been worse.... At least you werent blasting country music! er.... were you?
Old Feb 16, 2011 | 08:14 PM
unfortunately, due to the guy who owned the car before me, i am unable to have a functional cd player at the moment. he decided to pull out all the stock wires. i believe i have it in right, but no speaker sounds. i'm thinking the deck might be blown. gonna have the autozone guy test it.
so, thats a negative on the country music. however, if i had a functional cd player, i would have probably been blasting crue or judas priest.
anyone have a deck for sale?
Old Feb 16, 2011 | 11:11 PM
You might not need a new deck... You are VERY lucky! I happen to be an auto electrician and can look at it for you. Dont let the autozone guys touch it! ("Er....Hmmmm...So if i put the red, black and yellow wires together....") Bad news! What part of the valley are you in?
Old Feb 17, 2011 | 05:02 AM
the autozone guy knows a car electric guy, and had mentioned he was getting a new free deck, and i said i would buy his old one. i told him my woes, and he said he can get his buddy to test the deck.
im at 16th street and northern. the car doesnt move at the moment (emissions failures and previous owner cashed all the temp permits for this year.)
Old Feb 17, 2011 | 08:57 PM
What part of the emissions test is it failing? Nox, o2 etc...
Old Feb 18, 2011 | 04:35 AM
the first time i took it, i failed everything except fuel cap haha. took it in tuesday and faile evap, but that was because emissions guys are idiots and dont know how an evap canister is hooked up. and the other one i failed the second time was whichever one is 2.50 i think. ill get the paper back tonight and check it out.
Old Feb 19, 2011 | 01:28 AM
Probably NOX. Put 2 quarts of rubbing alcohol in a full tank of gas. U will pass.
Old Feb 20, 2011 | 06:36 PM
JP92RS's Avatar
Car: 92' White RS C5 wheels
Engine: 350 TBI
Transmission: 6-Speed
Drknow, how much can you get ls1s for? I'm thinking intake to pan with accesories. Maybe ecm and harness. I have a t56 out of a 97 firebird installed behind my 350 now. Can I still use my tranny?
Old Feb 20, 2011 | 09:25 PM
when i took it in tuesday, i drove from the shop getting a new catalyctic, and emissions i failed evap (because they dont know what a vapor canister is supposed to look like), failed the pressure test, and blew a 2.64 of NOX (2.50 is applicable standard)
then i took it to the waiver station, and they tested it again, failed pressure test, blew a 2.30 in hydrocarbons (1.6 is applicable standard, and it blew a 1.08 an hour earlier), and failed nox again with a 2.73. they passed my evap after they sent me on a wild goose chase for a hose fitting that doesnt exist.
yep.
been working on my caddy last 2 days, VATS went out. couldnt get to work yesterday, because phone is broken, and got canned. thank you VATS.
Old Feb 20, 2011 | 10:00 PM
MAN! Sounds like a bad day! As long as your car passes the visual and cap and tank pass the pressure test, then the rubbing alcohol will take care of the rest... Er...Ah... I mean "I heard" that it would work....Ah...Yeah...
Old Feb 20, 2011 | 10:18 PM
It is a different tranny. The input shaft is different. It can be changed, but you are better off getting a LS-1 tranny and selling your LT-1 tranny.
I can get an F-body LS-1 for around $1900.oo with tranny, Harness, all access and ecm.
Old Feb 21, 2011 | 07:59 PM
anyone have a stock suspension system to unload?
Old Feb 22, 2011 | 12:47 PM
What parts are you needing, exactly?
Old Feb 22, 2011 | 02:13 PM
I cant wait for the cruise ahh!!!!! DDD
Old Feb 22, 2011 | 02:40 PM
not certain yet. gotta find time to put it on jacks and see what the guy before me did to lower it.
Old Feb 22, 2011 | 07:21 PM
I have a pair of nearly new Bilstein rear shock absorbers (Valved for IROC cars) They have around 100 miles on them. Would sell for 40.oo for pair.
Old Feb 22, 2011 | 07:42 PM
sign me up
they would be fine on the gta?
Old Feb 22, 2011 | 08:16 PM
Yep! GTA/IROC, same valving. When you gonna come get 'em?
Old Feb 22, 2011 | 08:52 PM
you are up past sun city?? i dunno! after i track down some springs.. 2 weeks, month?
Old Feb 22, 2011 | 09:32 PM
I gotta get rid of them sooner than that. What springs are you looking for? I have a full set of IROC springs with 51,000 miles on them.
Old Feb 23, 2011 | 07:10 PM
Beater79TA's Avatar
You can buy new factory replacement Moog springs at OReilly's for less than $200 for all 4 corners. The fun is the spring compressor to get them installed....
Just remember, if your springs need replaced, the shocks are probably done too. The rears are fairly cheap. The fronts are not.
Old Feb 23, 2011 | 07:45 PM
uh oh! whats so tough about it in 3rd gens?
do you have the moogs? are they any good?
Old Feb 23, 2011 | 08:11 PM
Beater79TA's Avatar
Mainly finding a spring compressor. Most parts stores will try to rent you the one for a coilover setup which will not work on a thirdgen. The compressor you need has to insert into the inside of the front springs through the bottom of the control arm and then tighten to hold the spring from popping out. then you reverse the process to put the new one in. There are ways to do it without a compressor but the tool will definitely make putting the new springs in a lot easier. So will installing a Eibach ProKit which lowers the car by using a shorter spring.
The rear springs are easy. They just drop out when you lower the rear axle. Getting the new ones in usually requires 2 people to hold them while you raise the axle back up and rebolt the shocks but it isn't hard work.
And if you're doing the springs you probably want to track down replacement spring isolators at the same time. At least none of my front ones were reusable on the spring swaps.
Old Feb 23, 2011 | 08:59 PM
You arent kidding, Tom! They are a pain to get in. I had to do it the hard way, but all my cars have prokit springs! (And it still wasnt easy!) I couldnt find a compressor to rent that would work with it at all. I think he's trying to return it to stock ride height.
Old Feb 23, 2011 | 10:07 PM
Beater79TA's Avatar
I finally broke down and bought the correct compressor. I tend to run ProKit springs up front and stock in the rear to keep the car level after doing massive engine mods. Never had a problem getting the ProKit springs in and out but stock is scary to work with without a compressor.
Old Feb 24, 2011 | 04:47 AM
yeah, im all about stock. can i borrow your compressor?
Old Feb 24, 2011 | 11:43 PM
Tom, You need to get into an LS motor for your vert! Gotta love an aluminum engine block! Hows your RS doin?
Old Feb 25, 2011 | 12:06 AM
Beater79TA's Avatar
If you can wait about a month to pick it up. I'm out of town for a couple of weeks. You can rent them at Autozone though. You just have to make sure they rent you the correct one.
Old Feb 25, 2011 | 12:09 AM
Beater79TA's Avatar
Now why would I want to go and mess with a relatively low mileage engine that has 0 issues and doesn't leak anything? The LS might make more power and be lighter but there isn't any reason to tear into the vert for an engine swap. Especially when it's a 1 of 1294 ever made type of car.
The RS is due for another round of upgrades... battery relocation to the rear, different surge valve for the blower, new couplers on the intercooler piping, better tires, maybe a stereo system, and better front brakes. Then I'll see if I can get some consistency out of the runs. Until then, it's fun to scare the ricers with it just by driving by
Old Feb 26, 2011 | 02:27 AM
You do have a good point about the vert! It is nice to have a stock car to drive around! (Less issues, thats for sure!)
That IS one MEAN sounding car! Any chance you will have it streetable in time for the central cruise? Let me know if you need any rotors for those brakes. Got some Vette rotors in stock. as well as some Z-06 wheels (Polished C-5 spokes).
Old Mar 30, 2011 | 05:59 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
IVE GOT A KENWOOD KDC-X559 OWNED BY ME AND ONLY ME. BOUGHT NEW FROM CRUTCHFIELD. ITS THE BEST DECK IVE EVER HAD. ILL LET IT GO CHEAP. I NEED $$$ TO FINISH MY L98.
Old Mar 30, 2011 | 06:10 AM
i went to best buy and got a cheapo deck a few weeks ago. but if you got other fun goodies... pm me
Old Mar 30, 2011 | 03:51 PM
  #42
DRIVE2FAST's Avatar
PM SENT
Old Mar 31, 2011 | 01:35 AM
  #43
DRIVE2FAST: you need to tell us more about your project. I know it's in pieces, but why?
Old Mar 31, 2011 | 06:26 PM
  #44
DRIVE2FAST's Avatar
I BOUGHT IT NOT RUNNING. FUEL PUMP / SENDER / TANK WERE A MESS. I HAVE REPLACED TANK/PUMP/SENDER AT THIS POINT. I RE-SEALED THE B/W 2.77 REAR END AND THAT IS NOW INSTALLED. IN THE PROCESS OF REBUILDING ALL 4 BRAKE CALIPERS. REAR ROTORS TURNED. REPLACED FRONTS WITH JEGS DRILLED ROTORS. JUST FINISHED CUTTING SPRINGS FOR APPROX 2.5" DROP. SUSPENSION IS ALL BAK 2GETHER. IM KEEPING MY FINGERS CROSSED THE L98 AND 700R4 ARE OK........
Old Mar 31, 2011 | 06:32 PM
  #45
DRIVE2FAST's Avatar
SOMEBODY KALL ME FRI APRIL 8 FOR THE CRUISE ON CENTRAL SO I KNOW WHERE TO MEET YOU GUYS. 480 242 2090
Old Apr 1, 2011 | 01:34 AM
  #46
I'll let you know where to go before then. Check the new "central cruise" thread!
Old Apr 1, 2011 | 01:38 AM
  #47
sfeeney's Avatar
make sure i know i will pm you my number....
my ride should be in at least driving shape...
Old Apr 1, 2011 | 01:45 AM
  #48
Right on! I'll keep my eyes open for the PM!
Old Apr 1, 2011 | 01:46 AM
  #49
Oh, and I should have my LS7 RS ready for the next cruise! Might even be packing a Magnussen (SP) supercharger if I play my cards right!
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
ULTM8Z
Sep 16, 2015 09:15 AM
