South West Region South West regional discussion board.
Third gen tpi gas tank
Old 05-24-2015, 10:47 AM
LC2 TECH's Avatar
Looking for a TPI gas tank cheap. Doesn't need to be pretty but must have hanger assembly. Need it to mock up a new fuel sending unit we are going to produce.
thanks Lyle
Old 06-08-2015, 12:57 AM
ChainHartMachin's Avatar
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Transmission: 4L60E /700R4
Axle/Gears: 10 bolt 3.73 / 9bolt 3.27
Re: Third gen tpi gas tank
I've got a thirdgen tank with a TPI style sender just gathering dust. Are you planning to put it in a car that you would take to smog? If so it won't pass because vapor leaks at the filler neck junction (I tried epoxy and silicone to seal it). The filler neck sits a bit off center when the whole tank is mounted in the car (makes it tough to get the plastic filler panel in).
If these issues don't bother you then it's yours FOC as long as you can come get it.
Old 06-14-2015, 11:01 AM
LC2 TECH's Avatar
Nice to meet you and thanks again for the tank. Lyle
Old 06-14-2015, 03:06 PM
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Likewise! Glad you'll have a use for it.
Infested
05-22-2018 11:56 PM
Andrew6.688
12-13-2015 10:59 AM
mustangman65_79
09-01-2015 03:51 PM
AkDrifted
08-17-2015 07:45 PM
kyleb24
08-15-2015 08:24 AM
Quick Reply: Third gen tpi gas tank
