Anyone have extra prom and computer
Does anyone have an extra known good prom and computer? I’ve done a pile of diagnostic and have had two mechanics that are familiar with the system suggest that it’s time to try swapping in these parts to see if it fixes my issue. I’m in Ahwatukee. Phoenix south off i10 and chandler blvd. thanks. 1988 305 tpi with manual transmission. Computer 16198259.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Anyone have extra prom and computer
I have the 259 or 165 ecm, what letters are on your memcal ?
Engine: Lb9
Transmission: M20
It came with a hypertech 128852. I don’t know what it would have come with. Thanks. I hate throwing parts at a car and heard the old techs kept a few of these parts around for verification before purchasing the defective part. I’m not looking for any freebies, just hoping to pinpoint my cars challenge.
Engine: Lb9
Transmission: M20
The memcal linked will work, if your interested in it and a 259 ecm I can do both for $150 shipped.
send me a pm if I can assist. What issues are you having code 41 or 51 or just not running properly?
No codes. It had run great. Took car on 1700 mile trip and developed two problems. Random Ignition drop that was solved with ignition module and a failure to idle. I have not been able to solve failure to idle. Runs fine with est disconnected although with no advance of course. Iac has been replaced and always works fine when closing it for diagnostic. Tps has been verified, maf cleaned. Base idle set. When car is started it goes through it’s regular cycle and when it settled into normal idle it will drop and nearly die before car revs to catch itself. It will do this two or three times before it does die. One time after three drops the car went to a high idle and then settled into a great idle. I discovered at that point a code 42. It appears the car took the est out of play by itself After shutting off car and restarting it the next day the light was no longer on and est was active. I ran through the schematic for testing out code 42 and it came back all systems proper. Above idle the car runs fantastic.
Engine: Lb9
Transmission: M20
Wow, that is hard to say if it’s a ecm not controlling the iac properly or memcal.
i have a anpj 3:45 rear end ratio , it will work fine with other rear end ratios as well .
ElementsofSpeed
Jul 16, 2005 09:51 AM
CamaroX84
Sep 24, 2000 03:39 PM
