Southern California Area Southern California Members.
front end shake =/
Old May 18, 2002 | 12:43 AM
BrandenCali's Avatar
front end shake =/
Well if ya ever had any waves in your rotor an came to a quick stop from 65 down. the front wheel jerks and the car acts like it's got some pumps on the sucker =/
Well in my Red Roc my front end is doing that. And im pretty sure my rotors are ok. Although I could be wrong. Although a few weeks ago I did put in the Moroso solid trans mount an I did notice the vibrations. So is this our clue. better get that thing outta there before all my screws an bolts come out any other ideas on what could be ?
Old May 19, 2002 | 10:02 PM
Russ-So Cal's Avatar
By "solid trans mount" are you talking solid as in steel, or polyurethane? In either case, if the shaking started with the trans mount installation, you need to replace the mount with something softer.
Old May 20, 2002 | 10:52 PM
I put in a better trans mount
i used 1 of our good trans mounts from work. kragens suck bad. This mount should last a month atleast. depends on what I do. Yes I meant i had a Solid trans mount from Jeg's, I bought it So I wouldnt have to keep replacing mounts. I still yet have to get a better mount. With the solid mount out now it is smoother an I dont think my front end will shake no more.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
bamaboy0323
Sep 3, 2015 06:07 AM
