brake light fuse?!
brake light fuse?!
im sorry for the basic question but i appriciate any answers. i left my manuals at school so i dont have much to go off of. My brake lights arent working, and this is strange because i replaced all of them (including the 5 little ones for the third brake light) recently. i looked at the fuse box but the only one that i saw that had anything to do with brake is the stop haz one and that one is fine cause my hazards still work. is that not the brake light fuse? i have an 88 iroc if that matters. what else could it be? thanks.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I just went thru this problem, check my post below about my brake light switch. Its mounted on the column and contacts the brake pedal. Mine was broken. There is also a brake light fuse in the fuse panel under the dash, check that.
Ghettobird52
Jul 5, 2024 11:18 PM
